First lawnmower
/ First lawnmower #21
I still have what was probably my parent's first push mower. I thinks it has a Briggs & Stratton motor, but it doesn't have a pull cord. The top of the motor has a fold out crank that you to wind up what must be a spring. Then you turn a dial to release the spring and motor cranks over. Hopefully enough to start. Else repeat process.
Slower than a pull cord, but easier effort.
And the spring is still good?? As I noted in an earlier post, we had one of those in the early-ish 60s and I don't think that spring lasted one summer. Father replaced the spring once, new one didn't stand up any better, finally he said screw it, removed the start-spring assembly and would just manually wind a pull rope around the pulley to start it.
/ First lawnmower #22
The quality of those machines just jumps out at me from the pictures. Now everything is just such junky and often unecessary plastic, upon plastic.
/ First lawnmower #23
Yep, spring is still good.
I'll start it up every once in a while to see that it still runs. Which reminds me, it's that time of year again....
/ First lawnmower #24
Like so many things, one reason they are so junky is because that’s all we are willing to pay for. The higher quality mowers are still out there;Commercial Grade Self-Propelled Mowers - Heavy-Duty High-Performance Professional Self-Propelled Mowers - Bad Boy Mowers but why spend over $1000 for a mower when you can go to Walmart and get one for $150?
/ First lawnmower #25
Like so many things, one reason they are so junky is because that痴 all we are willing to pay for. The higher quality mowers are still out there;Commercial Grade Self-Propelled Mowers - Heavy-Duty High-Performance Professional Self-Propelled Mowers - Bad Boy Mowers but why spend over $1000 for a mower when you can go to Walmart and get one for $150?
Let's not forget, they made junk back then too. The quality stuff lasted, the junk got taken to the dump long ago. I don't remember my father ever getting more than 4-5 years out of a lawnmower when I was a kid.
As Jstpssing noted, will that $1000 mower last 7x as long as the $150 made-in-China one from the box store? Maybe, maybe not. The suburbanite will get by just fine with a cheapie, professional landscaper not so much.
/ First lawnmower #26
The first lawn mower we had back in the 50's was a two wheel Simplicity garden tractor with a front mount sickle mower. in the 60's we had a push type rotary mower that had the crank windup starter system on it; slow but worked well.
/ First lawnmower #27
bought our first house in about 74 and the neighbour had a manicured lawn that he ran a flymo over every couple of days, it was about all they were good for but if he went away for a week it would probably be too long for it to cut.
It was a very small area and it was not fast and you were limited by the length of the power cord.
/ First lawnmower #28
When I was in grade school my dad bought a small Rugg riding mower. It had 6hp and I got to drive it. I felt like "king of the world"! It was identical to this one.
