First big project with the bx25 is under way!
   / First big project with the bx25 is under way! #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
I am digging out the hill under my deck and pouring footers then handing off to a friend for block and brick walls. This thing kicks ***, it has exceeded my expectations so far.
   / First big project with the bx25 is under way! #2
Looks good!! Where are you in Maryland?
   / First big project with the bx25 is under way! #3
Great project. BX's rock.
Im in Bel Air MD, north of Baltimore about 30 minutes .
   / First big project with the bx25 is under way! #5
If you didn't have 4-wheel drive, I bet you would be stuck in that mud. I curios why you have to put new footers in and how deep do you have to go there to get below the frost line? Up here we got to go 42" down.
   / First big project with the bx25 is under way! #6
Yep powerful little machine that does wonders in tight spaces! Oh and a heck of a lot fun too.
32" here, footers for the block and brick wall going in, the columns are coming out
   / First big project with the bx25 is under way! #8
You can have some rock up there in , My sisters are up there and its a whole lot harder digging there than in sandy Anne Arundel county .
So far I have been lucky with the rocks, most of the dirt I'm removing was moved around when house was built.
SUCKER ROD W/PIPE RACK (A48992)
SUCKER ROD W/PIPE...
Vicon 3pt Fertilizer Spreader (A49251)
Vicon 3pt...
1/2" Universal Quick Attach Plate (A47371)
1/2" Universal...
Case International 8465 Automatic Baler (A49251)
Case International...
SCL850 Stand On Mini Compact Track Loader (A49251)
SCL850 Stand On...
MILLER CP-302 WELDER (A48992)
MILLER CP-302...
