First 50 Hour Service BX 2200
/ First 50 Hour Service BX 2200 #1
NY_Yankees_Fan
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
Did the 50 hour service on the BX2200 yesterday, here are the things I learned…..
1. To remove the engine oil filter you will need a filter wrench, the type that fits on the end of the filter with a hole in the center for a wrench. After trying to fit on a standard handle type wrench for 20 minutes, I gave up, when to the auto parts store and spend the $5.00 for the correct tool, you know what they say about having the correct tool for the job! A black wire bundle is right in the center of the filter, very little room to work. You would think the Kubota engineers could have thought that one a little better!
2. If you drop the front bracket for the 60" mmm and remove it , and turn the front wheels to the right, you can get the pan under drain plug to remove the oil.
3. I put in 3 quarts of Kubota 15-40W oil, book says it will take 2.6 quarts, not sure if this with changing the filter. Question, even with 3 quarts I am only about half way to the upper mark, did you fill yours to the top mark?, or is the middle OK???
4. Removing the transmission filter was not a problem, did not have to remove anything. The same wrench I used for the oil filter fit the transmission filter.
5. Removed the transmission screen it had some fine metal pieces, cleaned it out, and reinstalled.
6. I also removed the oil in the front axle, glad I did, as the oil was much darker towards the end. Remember to remove ALL of the breather plugs on the top of the wheels, I forgot to remove the plug on the right wheel, when I did, the liquid level dropped about an inch. I had trouble seeing how much oil was on the stick. So I used a piece of paper and laid the stick on it, now I could see where the liquid level was, worked great.
7. To fill the transmission, I took a funnel and put a 3 foot section of clear hose on it. Was just enough to reach the hole and stand up while pouring.
8. I think next time I will put some plastic on the garage floor to keep the oil from getting on it. No matter how careful you are, some will get on the concrete, well as careful as I was this is!
I bought a 5 gallon pail of Kubota Super UDT oil, glad I did, I would say I have less then a gallon in the can. I think with this much fun yesterday I will change the oil and filter every 50 hours instead of 100 hours! I hope this helps other back yard mechanics. Total time was about 3 hours, start to clean up. I hope when I go out to the shed in a few hours we have no leaks on the floor!
Tom
/ First 50 Hour Service BX 2200 #2
Tom, when I did my B7500 yesterday I discovered some really tight filters too. Those fellas at the factory must be using a cheater bar to install them. I have a couple pairs of Channellock "Big Azz" (real name on package) groove joint pliers that I bought a few years ago for tightening big thinwall conduit compression fittings. They made short work of it..................chim
/ First 50 Hour Service BX 2200 #3
You can get to the engine filter with a swivel handle wrench. I sometimes have to go from the inside of the frame, but it is accessible. On the UDT fill, if you remove the fill cap, then tilt up the seat, you can gain access to the trannycase from the breather vent. Pull out the breather vent and install a small funnel in there. It is a slow process, but far less messy. Don't forget to do those two fuel filters too.
Book says 500 hours on fuel filters change, did you do them at 50 hours? If so, what about getting air in the fuel line, I hear that is something you do not want to do.
Any comments on how much oil to fill with a filter change, and to fill it to the top line?
By the way, no oil on the floor, YEA!
Tom
/ First 50 Hour Service BX 2200 #5
I changed the fuel filters at the 300 hour service. I know the book says 500 hours, but I got nervous. My BX holds2 quarts, 24 ounces of engine oil (discovered after some trial and error. I also have less than a gallon of Super UDT left over from the 300 hour service.
/ First 50 Hour Service BX 2200 #6
I do all filters on the 50 hour service. And the engine crankcase does hold nearly 3 quarts. Take it to the top line. I think with the 70000 oil filter, it requires more than the spec book says. As far as bleeding the air out of the system, it is simple on the BX series because of the electric pump. After replacing the filters, follow the lines to the injection pump. There is an orifice bolt where the line goes in. Just break that bolt loose, and turn the key to the first position, and the electric pump will push the air out of the system. While it is still pumping, snug down the orifice bolt. Then fire it up, and let it run for a couple minutes, and it will smooth right out. I don't know if you are accessible to "red" fuel in your area, but if you are, it make s ahuge difference in the performance of the unit also. It has a higher cetane rating, and will improve the horsepower of the engine. If you don't have "red" in your area, then I would suggest getting the Kubota Fuel conditioner. It will boost the cetane rating of the "onroad white" fuel. Great little machines guys, take good care of them, and you'll be sure to get many useful years out of them.
/ First 50 Hour Service BX 2200 #7
I reached 50 hrs this weekend and will be doing the service one evening this week. What's the consensus on the fuel filter change at an earlier interval - I know the manual says 500 hours? I'll be heading to the dealer this afternoon to pick up the oils and filters and from what I've read it will run somewhere between $75-100 for the parts for the 50 hr service - correct?
/ First 50 Hour Service BX 2200 #8
It's your choice on the filters. I do them on the 50 hour. It may not be necessary, but just like break in's on tranny's and engines, I'm sure there is material within the tank when they are made, assembled so on. With two being on there though, probably not a huge concern. I just find it reassuring to me that they are fresh. Can't really tell ya on the cost of parts though. I know the Super UDT is not cheap.
/ First 50 Hour Service BX 2200 #9
sss,
When I picked up my filters and Super UDT it was cheaper to buy two 2.5gal jugs than the 5 gal pail. I even asked the parts desk fella about it and he said that's the way it works out. He mentioned I'd only need a 2.5gal and 1gal for the BX but I figured I'd use the extra for the front axle and to top off. The jugs are also easier to store and pour but more of a pain to recycle.
Enjoy,
Michael
This what it cost me for parts:
5 gallon container of the Kubota Super UDT oil: $60.60
Engine filter $10.06
Transmission Filter $15.07
Kubota 15-40W oil per quart $2.31
Grease for the FEL: $2.48
White grease in a spray can: $3.50
I will need to buy another quart of oil, it took 3 quarts and I am still not to the top mark. My dealer did not have 2.5 gallon continers of Kubota Super UDT oil, only 1 gallon, the 5 gallon bucket was cheaper.
Tom
/ First 50 Hour Service BX 2200 #11
I recently did my 50 hour service on my BX2200 also.
First I am glad to hear that you all have the same oil capacity as me, it took a little over three quarts of engine oil with filter change.
The dealer I purchased from is also a Deere dealer, I found out when trying to purchase super UDT fluid that they prep the Kubota's they sell with John Deere fluids. I first tried to find super UDT in my area then desided to go with what they said, for transmission-John Deere TY22000 Multigrade.
For engine oil-TY 22070 SAE 30. They assured me no Warranty problems or none down the road from using "green" fluid in an "orange" tractor.
I did not change my fuel filters but did go over the entire machine checking and adjusting everything mentioned in the 100 hour service.
Prices I paid;
Kubota 70000-15421 filter $4.95
Kubota K2561-36990 filter $13.70
Deere TY22000 $8.95 per Gallon
Deere TY22070 SAE 30 $1.88 per Quart
Don't forget it is a good time to service your attachments as well.
/ First 50 Hour Service BX 2200 #12
Kubota hydro cases come with S-UDT in them, and generally only need oil added when putting on a FEL or something that takes up some more oil. Since you have gone green, I would suggest you keep it that way now. I don't agree with mixing lubricants.
/ First 50 Hour Service BX 2200 #13
I have maybe a stupid question... or two:1. What do all you guys drain all this fluid into? It seems a regular oil pan would be way too small. 2. What do you do with all the used fuild?3. If you recycle it, where do you take it and how do you transport it?4. If you do take the used fluid somewhere (I assume an automotive service shop or something) do you mix it all up or does it have to be in seperate containers for different types of fluid?Thanks
/ First 50 Hour Service BX 2200 #14
Walmart sells an oil collection pan that will hold all the fluid I just place the OLD UDT back into the orginial bottles and dump in the recycle tank.
/ First 50 Hour Service BX 2200 #15
Make sure you find a low drain pan that can handle at least 2.8 gallons that's over 10 qts . Take it from someone who found out the hard way!
/ First 50 Hour Service BX 2200 #16
Larry,
I agree with you about not mixing lubricants.
My dealer implied the unit was shipped dry and they added the fluids during prep, they did not exactly say that but implied it. I did get a FEL with the unit.
With the super UDT being hard for me to get I think I will stick with the fluids I am using now. If I experiance any problems related to that I will be sure to let you all know.
/ First 50 Hour Service BX 2200 #17
My dealer said they only use super UDT while under warranty, then they use generic fluid... they see no difference. Also, they use only straight 30W "Case" diesel tractor oil.
- Patrick
/ First 50 Hour Service BX 2200 #18
We use the Kubota standard UDT after break in, expect on Hydros. All of our oils, grease, penetrant, everything in a bottle is Kubota. Except coolant. As far as receptacles. We generally have multiple pans. Napa sells a nice sturdy 3 or 4 gallon pan. As far as where it goes, we have a 300 gallon barrel, and once it is full, we call the local recycler company, and they charge us to suck it up. Funny, 10 years ago, they were paying us to suck it up!!!
/ First 50 Hour Service BX 2200 #19
Yesterday, I went to pick up the parts for the 50 hr service and both the parts and service departments told me that they don't change the hydro/tranny oil at the 50 hr service. They only change the filter at this point along with the engine oil and filter. The rational was that the filter will have removed any contaminants that entered during building and that the fluid should last at least 150 hrs under normal conditions before needing changing. They said its owner preference on changing the oil but that the filter MUST be changed. This is a large dealership with several locations across S. Texas and I've heard nothing but good about them from local farmers/ tractor owners. What do you guys think? I just bought the filter and 1 qt of Super UDT but will most likely go back today and pick up 3 gallons of Super UDT for the piece of mind.
/ First 50 Hour Service BX 2200 #20
I think the peace of mind is worth the 75.00 for the Super UDT. Does the dealership pull the screener/strainer out and clean it? I could not believe the amount of metal shavings on it when I did the 50 hour service. The first 50 hours had a much greater accumulation than the next 250 hours. If it was not for my brother and other Kubota owners telling me what to expect, I would have thought the transmission was damaged!
Based on that alone, I say change it!
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
Flatbed Truck (A55973)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 RTVXG-850 SideKick (A61306)
2023 RTVXG-850...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
Case SV280B (A60462)
