Firewood - Wood Splitter - Not Tractor Attached - Whats best?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
The Loggers are gone, I have 51 mostly empty acres now, and an astonishing amount of fresh cut giant tree tops to cut up for firewood.
I thought I needed a splitter before, I am sure of it now.
Do I go to TSC? Northern Tool? Craigs list?
I am thinking about selling some of this firewood as well.
I am all ears and listening closely.
Thanks in advance!
Be well,
David
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #2
How much you want to spend?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #3
TSC 22 Ton. $949. No brainer.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #4
I like the stand up splitter so you can roll big stuff in place and operate the lever .....all by yourself.
I have some large beech, oak, poplar, and maple rounds. All green fresh cut. Is 22 ton enough?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #7
I have a TSC 35 ton and it works for me. If I could change anything I would add a log lift instead of the vertical option. IMO.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #8
I looked at all the different types and models and wound up buying one of the DR Power Kinetic splitters. I bought the K55, which I believe is now discontinued. If I was buying right now, I'd buy the K22 which is available in gas or electric.
The kinetic splitters usually show up as being 3-6 times faster than hydraulic units measured by cord output. But I learned after using one that this is really deceptive: the difference is even more.
If you have small diameter rounds you are basically making three splits per piece to quarter it. But if you had larger rounds - and most of mine was 15-25" - you make many more splits per piece. So the much faster cycle time of the Kinetics makes them even more productive.
Very simple device and easy to maintain: change the belt every few years. Super Split makes models that seem more oriented towards commercial operation: not sure if there are other brands.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #9
Yes we split about two cords of oak last fall with some of the logs measuring in excess of 24" diameter. We were done in 6 hours. It goes vertical or horizontal and comes with it's own trailer. Very handy.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #10
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
378738 (A51573)
378738 (A51573)
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
More info coming soon! (A50322)
More info coming...
