Firewood - Wood Splitter - Not Tractor Attached - Whats best?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
The Loggers are gone, I have 51 mostly empty acres now, and an astonishing amount of fresh cut giant tree tops to cut up for firewood.
I thought I needed a splitter before, I am sure of it now.
Do I go to TSC? Northern Tool? Craigs list?
I am thinking about selling some of this firewood as well.
I am all ears and listening closely.
Thanks in advance!
Be well,
David
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #2
How much you want to spend?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #3
TSC 22 Ton. $949. No brainer.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #4
I like the stand up splitter so you can roll big stuff in place and operate the lever .....all by yourself.
I have some large beech, oak, poplar, and maple rounds. All green fresh cut. Is 22 ton enough?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #7
I have a TSC 35 ton and it works for me. If I could change anything I would add a log lift instead of the vertical option. IMO.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #8
I looked at all the different types and models and wound up buying one of the DR Power Kinetic splitters. I bought the K55, which I believe is now discontinued. If I was buying right now, I'd buy the K22 which is available in gas or electric.
The kinetic splitters usually show up as being 3-6 times faster than hydraulic units measured by cord output. But I learned after using one that this is really deceptive: the difference is even more.
If you have small diameter rounds you are basically making three splits per piece to quarter it. But if you had larger rounds - and most of mine was 15-25" - you make many more splits per piece. So the much faster cycle time of the Kinetics makes them even more productive.
Very simple device and easy to maintain: change the belt every few years. Super Split makes models that seem more oriented towards commercial operation: not sure if there are other brands.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #9
Yes we split about two cords of oak last fall with some of the logs measuring in excess of 24" diameter. We were done in 6 hours. It goes vertical or horizontal and comes with it's own trailer. Very handy.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #10
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
