Firewood handled only twice
/ Firewood handled only twice #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Ironwood (hornbeam) is an inconspicuous weed tree which grows beneath the maples, walnuts, and towering beeches of the forest crown. It fills in sunlit spaces if it can, and if not will stretch up forty feet until it eventually dies from root disease and falls over. Its cadavers litter the forest floor, often suspended a foot or so above the ground, dried like bones.
My dad built rail fences with them. He claimed ironwood rails would last twenty years, and a horse couldn't break them. But now that there's no more livestock on the farm, the dead ironwoods have become a mess of pick-up sticks.
I decided it was time to launch a small campaign to clean up the view from the trails.
My new Husqvarna 346 is light and fast. The 20" bar reaches the ground with little back strain.
At 44" in width and with excellent ground clearance, the Bolens G174 can get to any part of the woodlot to pick up cut blocks.
Last winter I discovered that the Walco 3 pt hitch dump box on the Bolens holds as much firewood as the 5 foot bucket on the larger tractor. What's more, it can back directly into my workshop and unload at the woodpile beside the stove.
Think of it: firewood handled only twice.
But a run back with the Ranger to cut a couple of ironwoods and then returning with the tractor to haul it out seemed wasteful to me, so on a wet day I built a scabbard from two 6" boards rabbetted to create a slot for the saw's blade.
First I bolted it vertically to the bumper of the tractor. That worked fine until I tried to change the oil. Oops. Couldn't open the hood. Off it came. Internet searches offered no real suggestions apart from the odd bit of butchery of the tractor's sheet metal. The scabbard wouldn't mount behind the seat. There wasn't room on the little tractor.
Then I looked at the right fender. If I could hold it in place there, it wouldn't interfere with much of anything. A leftover fitting from a plastic tractor canopy fitted over the handrail and bolted the scabbard in place. A loop of string slipped over the starter cord to keep the saw from working its way out while underway if I forgot to set the chain brake.
It takes an hour on a fine day to cut enough ironwood to fill the box, bring it to the shop and add it to the woodpile. No block is larger than 6" so the splitter isn't needed. The surprise is how well the forest-dried wood lasts overnight. Ironwood, it turns out, makes excellent firewood.
There'll still be lots of use for the logging winch, the hydraulic splitter, the loader on the tractor with a cab, even the manure spreader with beaters removed, but firewood handled with all of this equipment requires many stages of production and quite a bit of diesel.
The little tractor-with-saw-attached system uses less than one quart of diesel per hour of operation and requires little strength of its operator. It looks like a system which could work for me well into my seventies.
/ Firewood handled only twice #2
Nice, I have an old Bolens Tractor that I inherieted from my FIL...I think it is about a 1960's model, a bit smaller though. When I got it, the motor was shot, so it Hasn't ran for several years now. I have always been on the lookout for something that made sense to do with it....
/ Firewood handled only twice #3
We have a lot of "ironwood" as well here and it burns great. I agree they are not the prettiest of trees and are the first that I cut down if at all possible. I do split some of mine though as my masonry heater works best on smaller chunks of wood rather than solid pieces. I like your idea of handling wood twice as that is how it should be.
/ Firewood handled only twice #4
Looks like a good setup, I wouldn't mind finding one of those carry-alls like that for my B3200. How much weight do you need on the front end for a full load of wood? I'd love to see some pics loaded and out in the woods.
I carry three suitcase weights on the front to balance the 48" rotary mower which weighs about 450 lb. When I dug down a basement floor and filled the box with rocks and dirt it would become quite light in the front end with the box nearly full. I can't get enough firewood into it to lift it at the front.
The 8000 pound logging winch in the attached photo is too heavy for the tractor, but I can steer it well enough.
/ Firewood handled only twice #6
Wow- that is a whole lotta winch for that tractor!!! :shocked:
/ Firewood handled only twice #8
Thanks for the pictures
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
HONDA Plate Compactor (A64557)
HONDA Plate...
2022 CATERPILLAR 950M WHEEL LOADER (A65053)
2022 CATERPILLAR...
2012 FREIGHTLINER M2 6X4 T/A ROLLOFF TRUCK (A66091)
2012 FREIGHTLINER...
Dixie Chopper (A64557)
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
