Fireplace help
/ Fireplace help #21
I cut down a dead elm this summer that was about 3 foot diameter at the base. I tried splitting a piece of that a few days ago with my maul. I couldn't even tell where I hit it. Looks like I now have an indestructible base on which to split more agreeable wood.
Chuck
/ Fireplace help #22
I helped a friend cut up an Elm after a storm this fall. It cut nice, but when I took my wood splitter over a few days later to split it, we had lots of fun. When it split like wood should, the water would run out of the wood almost like squeezing a sponge. Anyplace where there were branches it took all the power my splitter had to make any progress. The wood was extremely stringy making it hard to separate the pieces after splitting. Maybe after drying for about 3-5 years in might split better. But anyway it was a valuble lesson that I hope I don't forget.
Joe W.
/ Fireplace help #23
Chuck and Joe,
We had a blight come through here a few years ago and killed a bunch of Elm,I cut some of them down and what you could get in the firebox or fireplace would burn great.
/ Fireplace help #24
I haven't found wood debris in the chimney to be too difficult to handle, at least not like the soot created by the oil burning boiler that I once had. But your recommendations are good precautions to take.
/ Fireplace help #25
Hi Jim
I tried an open fireplace for two winters, and like you I was constantly feeding it with wood for very little heat return. So l bought a Jotel wood heater, blocked the fireplace with a piece of fibreboard and ran the flue from the heater's rear directly into a hole drilled into the fibreboard, I didn't even pipe it up into the chimney. It works beautifully, is extremely economic and the amount of heat thrown out vastly justifys the initial expense of the heater.
Regards
Chris
PALLET OF MISC ITEMS (A68842)
PALLET OF MISC...
2012 PUMA BUMPER PULL (A67714)
2012 PUMA BUMPER...
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
2009 FREIGHTLINER CST120 (A67714)
2009 FREIGHTLINER...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
3 PALLETS OF WHEEL/TIRES (A68842)
3 PALLETS OF...
