Firefox freezing up; will not shut down.
   / Firefox freezing up; will not shut down. #41
I have a problem with FF not showing prices on For Life Out Here | Tractor Supply Co. . Does anyone else?
TSC requires a US Zip code and I cannot supply one. (I'm in Canada) That being said, if you look at the top of the FF window beside your address bar you may see a round white ball with a 'S' in it. If you see this then put your mouse pointer on it and a list of commands will appear and one of the commands will be 'temporarily allow Tractor supply', click on that command and the prices will appear.[Do this after you give them the needed Zip.]
If the 'script blocker' is a PITA for you then just delete it through your 'tools' menu. It is under 'extensions'.
   / Firefox freezing up; will not shut down. #42
Firefox 37 was released today. Updating to it may fix your guys problems. Good luck.
   / Firefox freezing up; will not shut down. #43
If I use any other browser, it works fine. There is no " round white ball with a 'S' in it.".
I'll try ver 37.
   / Firefox freezing up; will not shut down. #44
I'll try ver 37.
I believe the poster was referring to an add-on for fire fox called no-script that some people use . It blocks FF from running scripts . It is not included in FF . It has to be downloaded and installed . If you have no white ball with S , you don 't have the add-on .
   / Firefox freezing up; will not shut down. #45
Funny I do have no script running. The 'S ball' is way over to the right but I didn't see it there.
I've temporarily allowed tractorsupply, and white listed it also. Still nothing. I just disabled noscript.
Still nothing.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3.75 Ton Crane Service Truck (A55973)
2017 Ford F-550...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55315)
J and L Cargo...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
