Firefox freezing up; will not shut down.
   / Firefox freezing up; will not shut down. #41
I have a problem with FF not showing prices on For Life Out Here | Tractor Supply Co. . Does anyone else?
TSC requires a US Zip code and I cannot supply one. (I'm in Canada) That being said, if you look at the top of the FF window beside your address bar you may see a round white ball with a 'S' in it. If you see this then put your mouse pointer on it and a list of commands will appear and one of the commands will be 'temporarily allow Tractor supply', click on that command and the prices will appear.[Do this after you give them the needed Zip.]
If the 'script blocker' is a PITA for you then just delete it through your 'tools' menu. It is under 'extensions'.
   / Firefox freezing up; will not shut down. #42
Firefox 37 was released today. Updating to it may fix your guys problems. Good luck.
   / Firefox freezing up; will not shut down. #43
If I use any other browser, it works fine. There is no " round white ball with a 'S' in it.".
I'll try ver 37.
   / Firefox freezing up; will not shut down. #44
I'll try ver 37.
I believe the poster was referring to an add-on for fire fox called no-script that some people use . It blocks FF from running scripts . It is not included in FF . It has to be downloaded and installed . If you have no white ball with S , you don 't have the add-on .
   / Firefox freezing up; will not shut down. #45
Funny I do have no script running. The 'S ball' is way over to the right but I didn't see it there.
I've temporarily allowed tractorsupply, and white listed it also. Still nothing. I just disabled noscript.
Still nothing.
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
1449 (A57192)
1449 (A57192)
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2020 DRAGON ESP...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
2012 Chevrolet Silverado 2500HD 4x4 Service Truck (A56858)
2012 Chevrolet...
