FIRE!
/ FIRE! #1
schmism
Super Member
Peoria IL
New holland TC(33)
dont know if i ever posted any pics from our house burn last year.
I had hosted them on our website shortly after but never got around to building a page for them till now.
anyway found a few tractor related ones in there also.
a few teasers
the astute observer will note that after you have dumped 500 gal of water on the ground next to the house, it gets a smig soft.
that pile of ash you see, at the center of it is a pile of 4 mattresses that were on the second floor in a bedroom. a week later (after being gone on vac) i pushed that pile around with the FEL to find hot coals in the center hot enough to start dry brush on fire i piled on it. (on purpose)
find all the pics at http://www.snjschmidt.com/burn.html
/ FIRE! #2
By the looks it didn't take long once the fire got going...I would have little seat pucker fifth pic. tho. ;)
/ FIRE! #3
You should be ashamed, burning down a perfectly fine fixer-upper like that:D
Mark
/ FIRE! #4
Interesting. In the pictures they have an engine drafting from the portaable pool, with a Tender filling it.
We have a similar porta pool on our Tender, but it has never been used. Cases like this, we usually wind up with multiple Tenders responding. We have five in our district(we cover a very large area), and the surrounding districts have at least one each. All are 2700-3000 gallon Tenders. The Tenders then pump to the Engines.
/ FIRE! #5
I hope you thought to pull up the doorsills and baseboards/shoe molding before you burned it?? No telling what you might have found underneath them! Sometimes you find some nice silver coins, tokens, etc. under their.
/ FIRE!
this is standard procedure with a dump tank. The tender is free to dump its 3K gallons (in about 45 sec) into the waiting (nearly empty) 3500gal tank and return to get another load. (cutting 5-8 min out of the cycle time)
as our pumpers are setup with 6" hard suction we can easly draft 1000+ gal per min needed, were as a direct connection with 3" soft line to a tender will net you only about a 1/3 that.
/ FIRE! #8
We're set up the same. I just have never seen this done in our area. I don't know why. We have a lot of area without hydrants. There are a number of Tenders locally though too. Will have to ask at training Wednesday.
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
