Fire Wood Question
   / Fire Wood Question #1
CharlieTR
NE TX
Long LongTrac
I am looking into getting a wood burning stove and installing it before the clod weather this year. There are a good number of trees I can access but none are Oak. They are smaller and are not evergreens. I read that hardwood output around twice the BTU as the evergreens. Does that apply to any hardward (trees that loose leaves in Winter)?
   / Fire Wood Question #2
Wood of different species produces about the same amount of energy per pound. Look up a table showing the weights of wood or densities and you can tell the amount of heat produced.:D
   / Fire Wood Question #4
Here is a chart that may help you.
Sweep's Library - Firewood BTU Comparison Charts
Firewood needs to be seasoned at least 1 year to burn well. 2 is even better. If you cut now and use it this winter, it will be "wet" and won't throw much heat. Plus, the moisture in the wood can cause creosote buildup on your chimney - chimney fire hazard.
I would say try to find someone selling seasoned firewood to use this year, and you can start cutting next years wood now.;)
   / Fire Wood Question #5
If you are going to burn unseasoned wood I would recommend ash. It splits well and burns "ok" green, but I agree with TheHammer. Jay
   / Fire Wood Question #6
My favorite firewood is not on those charts. It is hard to get in many areas but Pecan is about the best firewood and is also perfect for smoking and BBQ.
   / Fire Wood Question #7
I've heard madrone is the best there is. Anyone burn it?
   / Fire Wood Question #8
I used madrona for 8 yrs its a great wood to burn, great coals.
Just dont drop any on your toes:eek: even a little piece weighs a lot, it has a very paper thin bark which makes it slip out of your hands easily.
   / Fire Wood Question #9
Madrona is great, very dense...
IMO, Unless you are buying already seasoned wood, you are a little late in the year to be planning a woodstove for this winter. IF you are buring really green wood, watch for chimney buildup. Green wood dosn't burn as hot and as clean and you will buildup/condense more cresote(the stuff that chimney fires are fueled by) on the chimney lining.
Oops, is there an echo in here? I missed TheHammer's post the first go around. What he said:)
   / Fire Wood Question #10
Madrona is excellent firewood. As someone else noted, it is heavy too; very dense and good burning. I am not sure of availability though; it is common around here.
It is, also, a nice winery :D Madroña Vineyards It is also only 15 minutes from my house.
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2012 Chevrolet Traverse LTZ SUV (A55758)
2012 Chevrolet...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
7022 (A50322)
7022 (A50322)
