Fire Plugs
/ Fire Plugs #41
cjcocn said:
That's a good question. For all I know it could be because old water mains were wood and had plugs in them for water supply access. But then again I ain't been learned as much as some of these other fellas here. :D
that is pretty much it. they would also drill in to the main if needed, to get as close to the fire as possible, and plug the hole once the fire was put out. Hence, fire plug :D
/ Fire Plugs #43
Our area is mixed with some hydrants and some with out we use tankers for first strike, and have a tanker task force (11 trucks 2 fill pumpers) on second call for the areas with out any hydrents.
We also have a LDH (large diamater hose) task force can supply about 1000 gallons a minuet fro a mile ususlly from a draft and takes about 20 pumpers to functiin properly. that can bring the hydrant to you.
tom
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
429133 (A61165)
429133 (A61165)
UNUSED MGY-100KW FUEL HEATER (A62131)
UNUSED MGY-100KW...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Heavy Duty D Ring Shackles (A61568)
Heavy Duty D Ring...
