Fire extinguishers use on farm???
/ Fire extinguishers use on farm??? #1
creekbend
Super Star Member
Yanceyville, North Carolina
Kubota L4400
I am a relatively new member and I have reviewed many threads and posts regarding safety issues. Wondering how many members out there have fire extinguishers on their tractors, in their shops, and other locations on your farm. Thanks for your replies from Creekbend.:tractor::tractor:
/ Fire extinguishers use on farm??? #2
I do! I have shop size extinguishers (dry chemical) in the barn and in the garage. I keep water near by when welding, and the dry chemical is if I have flammable liquids out (thinner, oil, etc.)
I have a metal trash can for oil soaked rags too.
One of the first things I did was replace the rusted out old breaker panel in the barn, and add GFI breakers for the outlets. Apparently the panel manufacturer went out of business because of fires...
I wish I could put in a deluge system in the barn, but I don't have a water supply that could make it effective, so prevention is the key.
Did I mention that I'm retired Coast Guard? Semper Paratus!
I have two fire etinguishers on my ROPS attached by brackets, in my shop and sheds, and a metal trash can for combustible rags.etc also. I have water tanks in my barn. Thanks for replying.
/ Fire extinguishers use on farm??? #4
Have them on the tractor. There is a DNR requirement to have them on or with machinery when operating in a forestry environment in our area. Different ratings depending on the type of equipment. Also just a fine idea in general.
/ Fire extinguishers use on farm??? #5
my tractors have em.. my trucks have em.. and my barn has em. anything I don't want to watch burn tot he ground has them...
soundguy
/ Fire extinguishers use on farm??? #6
I got half my face and neck burnt real bad. Fire scares the pee outta me now.........so it ain't gotta chance.:thumbsup:
/ Fire extinguishers use on farm??? #7
I have a good friend who sells, and fills fire extinguishers. He has lots of out of date units that we sometimes do unscientific testing with.
There are several things you learn very quickly:
Those 2.5 lb dry chemical extinguishers might make you "feel" safer, but your not going to put much of anything out with one.
The smallest dry chem extinguisher worth having is a 10 pounder.
There is no such thing a too big. It's only too big, if your too old to grab it, and run with it.
The instructions for a fire extinguisher all leave out one important step, HOLD BREATH. If you don't take a deep breath, and hold it, you will probably inhale some of the contents, and you will regret it.
Get in close. If you don't have a 400 lb. Ansul, your only going to have a number of seconds to put out the fire. If your not right up in it, you may as well throw the empty bottle on the fire, and go get some marshmallows.
If you simply cannot fit a 10 lb. extinguisher on, or in the area you want to protect, the only small extinguisher you can really put out a fire with is a halon unit. You can't get "real" halon anymore, (thanks EPA), but there are environmentally friendly halons out there now, that work. The problem here is they all cost well over $100.
Halon is so effective, you can put out a candle on one end of in your living room, standing on the other end, facing the wrong way, with about a one second blast of a halon extinguisher. Halon is a gas, so it is going to be effected by winds, when you use it outdoors.
A really hot fire, like an engine fire, is best put out with water. Anything else may work, but the fire can keep reigniting from the heat, and your probably not going to have a big enough extinguisher to keep putting it out. I discovered this on the highway last year, trying to help a motorist.
/ Fire extinguishers use on farm??? #8
i'm not a big fan of dousing an oil fire with water... unless it from a fire hose and i'm 30' away..
soundguy
/ Fire extinguishers use on farm??? #9
I have got a 10lb CO2 extinguisher in the shop where I do my welding, Since I have an O/A torch, I need a CO2 extinguisher. You can get them quite cheep used, I got mine from the fire supply place, it was out of hydro test date, and needed a new valve. I bought it like that for $30, and got it re tested and filled, for another $30, so for $60 I got the perfect fire extinguisher.
/ Fire extinguishers use on farm??? #10
soundguy
I never suggested that.
/ Fire extinguishers use on farm??? #11
this would seem to show otherwise:
I expect to find fuel ( oil ) and well.. OIL in an engine..
If I had a fire hose or high volume hose.. that's one thing. I wouldn't want to use a low volume or bucket on something like that for fear of splash spreading the fire.
then again.. you use what you got. if it's a choice of burn tot he ground or water.. go with water.. :)
soundguy
/ Fire extinguishers use on farm??? #12
soundguy
No, there is a difference between an engine fire, and fire in some grease or oil.
/ Fire extinguishers use on farm??? #13
Well except for the air cleaner, and the plastic, basicaly all that can burn on an engine is oil.
/ Fire extinguishers use on farm??? #14
Yes on a tractor, but the kind of engine fire I was referring to was an automotive vehicle fire.
Under the hood there are lots of plastic things that will burn when the temperature gets high enough, including the paint. You have an air box, heater box, fan(s), wiring, battery covers, engine covers, hoses, belts, etc.
I occasionally saw vehicles with these kinds of fires, or vehicles that nearly had these kind of events, working in the automotive repair business. These engine fires were usually the result of either the exhaust overheating due to the catalytic converter(s) being blocked, (I won't explain how that happens here, but it is easy for this to happen if you have a problem with your engine), or an electrical short. Yes, there can be other causes, but these are the most common. Both of these events can produce temperatures that result in red hot glowing metal. I personally have seen about a half a dozen glowing hot catalytic converters over the years. These vehicles were minutes away from going up in smoke.
Because of the extreme temperatures involved, you will find you probably cannot put one out with a fire extinguisher. The firemen who eventually put the out fire I attempted to extinguish, agreed. This is because you probably won't be able to get the hood open, and the extreme heat will keep reigniting it until you run out of extinguisher.
/ Fire extinguishers use on farm??? #15
There might be some MAGNESSIUM under that hood? The stuff really is hot, bright. and persisitant when on fire. halon? Hard to come by now, a refrigerant variant, and as usual not real good to breathe, it smothered the fires. I like powder and co2 myself..
/ Fire extinguishers use on farm??? #16
I've got a couple of the larger fire extinguishers in my garage and house (10lbs?) and a couple of smaller ones.
I once lived in a apartment building that had a cloths dryer catch fire. It was in a commons area and I put the fire out with one of those smaller ones. Like Ray66V said, they won't put out much of a fire. I pretty much emptied it out with a 2 or 3 second burst, and like he said, I got up pretty close to the fire to make it work. The fire was in the lint and socks behind the drier, it if hadn't been out in a fairly open area, the extinguisher would have been pretty worthless. Like he said, you can't really get to big.
/ Fire extinguishers use on farm??? #17
The 3 vehicle fires i have been present at were a suv of some sort, had an unspecified fire at / under the engine onthe side of the road, a car in a parking lot that had a shorted alternator causing a fire, and a semi truck that had an electrical short in the wiring from the truck to the trailer.
In all 3 cases a dry powder extinguisher put the fire out, including the burning grass under the suv engine compartment.
fire in the car would start back up untill we knocked the wire off the alternator, and same with the semi.. a bolt cutter was quickly applied to the hot cable to kill it.
2 of those were 10 BC extinguishers, as they were out of my truck, and that was what I was carrying when i pulled over / in.. I don't know what the 3rd was, as I grabbed it off the wall while heading out the door when i saw the burning semi pull into the shop yard...
Fire Extinguisher: 101
This backs up what I've always heard, especailly growing up with a father that was / is a fireman / fire inspector.
class A extinguishers are pressurized water, and are not reccomend for oil and grease fires.. or electrical fires ( C ).
There are also specific K type ratings for cooking oil fires.
A vehicle fire, is likely going to be a B/C IE.. dry chemical ( B ), and non cunductive media ( C )
soundguy
/ Fire extinguishers use on farm??? #18
Thats why I like the CO2 extinguishers, because they have a huge cooling effect, and why they are best for a fire with supplied O2 (like an O/A torch), because they bring it below ingition temprature.
/ Fire extinguishers use on farm??? #20
Great topic! I have carried extinguishers on most everything for years, and have received a lot of blank stares/quizzical looks as a result.
Here's the bottom line, based on 3 decades in the fire business;
You need an extinguisher capable of preventing a small fire from becoming larger, in whatever fuel type it is likely to occur...
That's why a 2A10BC extinguisher is so common in a typical business- it is rated for A-common combustibles (paper, wood); B- flammable/combustible liquids (fuels); and C- energized electrical devices.
There are automotive-oriented extinguishers that are better suited for use on a tractor (see you local auto supply or fire extinguisher dealer), as they are geared towards the most likely fires therein (wiring, other electrical components and fuel)
You will not be able to extinguish a large fire in a tractor, BUT, your extinguisher may keep a small fire small, or, at least keep a "loser" situation from spreading to vegetation, vehicles or buildings.
Finally, how many have considered carrying a shovel and water with them in the woods/fields (in addition to an extinguisher)? As was mentioned by an earlier poster, it is required in commercial operations in the woods, but seldom thought of on farms until after an event.
I carry a shovel and a hand-pump device with 5 gallons of water during the summer and fall. Even if a machine fire results in a total loss, these tools can prevent said loss from spreading. In the mean time, you may encounter grass/brush fire as a result of saw work, brush cutting, or some hapless neighbor with a shortage of common sense.
Like wearing seat belts, carrying an extinguisher is not an infallible strategy, but the odds are good that you'll be able to make a difference.
Otherwise, its a pretty bad feeling to stand by and watch something burn because you were not equipped to take action!
