FIRE ANTS
   / FIRE ANTS #11
The fire ant populations here comes and goes. I think it has to do with the parasite that turns them into zombIes. Currently the ants in decline in my pasture. I've read that SC has a breeding population of the parasitic flies.
If I line my round bales up so the ends don't touch it keeps the little buggers from nesting over half way up to stay dry. They still get around the bottoms of some bales.
   / FIRE ANTS #12
Go to YouTube and look up Anthill Art. Link below.
You can start a second career!
My dad put something on them in our yard in about 1980 and they never came back. Couldn’t have been very Enviromentally friendly.
Oddly, satisfying to watch!
   / FIRE ANTS #15
Bifen IT. Mix 1 oz per gallon of water.
About a half gallon of the mix per mound.
Bifen is a “persistent” insecticide so as long as it doesn’t rain too much it will continue to be effective for a month or two.
I tried that with my 25 gallon tractor sprayer. I had 3-4 acres peppered with mounds. I just drove around and saturated a 3 foot diameter over each mound. Just to make sure the queen at the botttom gets toasted I stick the wand in as far as it will go, up to 18" deep. Saturated the whole mound basically. That took care of ants for the year, but they start coming back because you can't get them all. I need to do that every year at least once.
   / FIRE ANTS #16
Best I hope for is I run them off to the neighbor's property. Amdro will work for a little while. Orthene is the same. After a hard rain they are washed away, although then it is easy to spot new mounds.
   / FIRE ANTS #18
Might not stay long but I've always used a good strong soapy solution of Dawn liquid and water. Works on those big European/Asian hornets we sometimes get around here. If the solution doesn't start killing them inside of 10 seconds you need more Dawn liquid. Non-toxic, cheap, available everywhere. By the bucket or in a pump spray bottle. For the fire ants get a shovel full turned over until you see eggs. Moving quickly to complete the task is advisable.
   / FIRE ANTS #19
Extinguish fire ant killer works but it is not cheap.
   / FIRE ANTS #20
I have been treating fire ants on athletic fields for many years. There are several key points to consider for fire ant control.
1. Treat when fire ants are active. That usually occurs when temps are warm, but not excessively hot.
2. Treat the entire area, not just individual mounds. There will always be small mounds that you will not see.
3. Ants will begin moving back in from untreated areas fairly quickly. The larger area you treat, the longer it will take for them to invade it all again. This is somewhat dependent on the pesticide you use.
4. Some treatment options will last longer than others. Fipronil will last longer (up to a year) is more expensive, and is more specific to certain species. Bifenthrin won't last as long, but will kill many more insects, such as mosquitoes, and army worms, and is less expensive.
I usually use bifenthrin because I like that it gets mosquitoes. There are other options.
Please always read and follow the label on any pesticides you use.
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
10' Container W/Side Door and Window (A57149)
10' Container...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
TROY-BILT PUSH MOWER (A58374)
TROY-BILT PUSH...
Swict 78" Bucket (A57149)
Swict 78" Bucket...
