Finishing Mower
/ Finishing Mower #1
Rastis
G'Day Diggers,
I have a Kubota B6200 4WD tractor which I use for inter-row spraying of Sugar cane. From memory this tractor has 15 hp at the motor and 12.5 PTO hp. Will this tractor run a 4 foot finishing mower. I have 3.5 acres to mow and it takes me 6 hours at the moment with the 30inch Greenfield ride-on. The Kubota is only used a few times a year for spraying, so if I can utilise it for mowing it will save me buying a new ride-on.
Have a nice day,
Rastis.
/ Finishing Mower #2
There are 42" mowers available too, so you might want to consider that size.
Both Befco and Land Pride recommend a minimum of 15 HP to operate a 48" finishing mower. Your PTO HP is a bit less then the recommended HP. I'm also thinking that Kubota doesn't have adequate 3PH capacity to lift a 48" mower.
However, I ran a 60" rotary cutter with a tractor that had substantially less HP then recommended.
If your property is flat (reasonably) and you don't need to transport the mower (raised on the 3PH), I'd give a 42" or 48" unit a try. I think as long as you don't let the lawn get too out of control, you'll be OK
/ Finishing Mower #3
My personal opinion; I think you'll be just fine with a 48" finish mower.
/ Finishing Mower #4
I ran a 60” woods rear mount mower on my B6000 for years. It did fine, even in tall wet grass.
Gary
/ Finishing Mower #5
"My personal opinion; I think you'll be just fine with a 48" finish mower. "
The true voice of experience! So, looks like a 48" unit is the way to go.
/ Finishing Mower #6
You should be fine with a 48" finish mower. I run a 48" brush mower which is tougher to do with 15.5 and I can see that I could use it with less HP.
A finish mower should be a little easier if you're not having to cut extremely overgrown materials. You could take an even smaller bite the first time if it's high.
John
/ Finishing Mower
Hi Chaps,
It seems that the 4 footer is the smallest mower available over hear in Oz. The local dealer said I can give it a test run so I will see how it goes. If it is a bit heavy I can put more weights on the front.
Thank You,
Rastis.
/ Finishing Mower #8
My Ford 1100 is only rated 11 hp at the PTO and it seems to run a 48 inch finishing mower just fine....so I think you'll be OK....
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
John Deere 772CH (A64126)
John Deere 772CH...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2002 Pace American of Texas T/A 26FT Enclosed Trailer (A61573)
2002 Pace American...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
