Tractor Sizing Finishing Mower Size for YM1601D
   / Finishing Mower Size for YM1601D #1
frankmako
North Georgia
Ford 4610, Ford 3910 and YM1601D
What size will a 1601D pull on flat ground. All way heard bigger was
better, but I don't want to over load the tactor. Should I get a four
foot or go with the five foot. Seen several good deals around my area
on used mowers. So what do you have on the back of your 1601D and/or
same size tractor?? Thanks guys. Frank
   / Finishing Mower Size for YM1601D #2
A ym1601 has I believe to be 19-20 hp engine, it would easily run a 5 footer, and most likely a 6 footer. My opinion based on experience.
   / Finishing Mower Size for YM1601D #3
I tried my 6' finishing mower behind my YM1700 and in my opinion, it worked the tractor a little to hard. I found a used 5' Woods finishing mower and use that behind the 1700 and it does good. If the grass is tall it will still lug the tractor so I have to cut a little more often which gives me more seat time. So with this said I believe you will be happier with the 5' mower.
I use the 6' finishing mower behind my JD.
   / Finishing Mower Size for YM1601D #4
Usually the problem here is the tractor will run a larger mower than it can safely lift. A 6' deck on a tractor this size will pull the front end up quite easily if it will even lift it, a 5' is gonna require front end weight to keep the nose down. Might even need some front weight for the 4' to be safe. I have a larger machine and I beleive I could easily run a 7' or 8', but at full lift with a 5' deck a quick hit of the brakes in reverse will bring the front up a bit.
   / Finishing Mower Size for YM1601D #5
You are correct and I should have stated that I had to add about 80 pounds of ballast to the front of the 1700 to safely handle the 5' mower. Even with the weight on the front I did a couple of spectacular wheelies with the 6' mower so I no longer use that mower with the 1700. My heart and the seat could not stand that excitement.
   / Finishing Mower Size for YM1601D #6
I run a woods RM 59 on my YM135 and it doesn't seem to have any problems. It does bog sown a little in the high grass but not to the point of needing to downshift.
I agree on the front getting light so I put 200-250 pounds of weights on the front and it is much better now. It has plenty of lift strength just not enough front weight. It is still a little light but I have a very flat yard and I will be careful.
YMMV
Andy
   / Finishing Mower Size for YM1601D #7
I have a 1610d which is the same hp as yours,I run a 4' First Choice mower,no problem.The 4' is small enough to get around trees etc.I mow approx.11/2 acre.I used to take the fel off but lately have left it on.I used the same mower when I had a 1510 w/o a fel.First Choice is made in Italy and it's a very solid made mower.
   / Finishing Mower Size for YM1601D #8
I ran a five foot belly mower on my 186D (15 @ the PTO). I will say the RPMs dropped a little in tall thick grass....... you sould be good to go on a five footer.
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
