Finishing mower blade removal question
   / Finishing mower blade removal question #1
SgtSluggo
Middle TN
John Deere 4105, Ford 1700
So I now have a Farm King Y750R finishing mower. It sat in a field for about a decade before I pulled it out to try to get it working. I was able to get it running, but I am really struggling to get the blades off for sharpening/replacement.
I don't have a real breaker bar, but I am also not sure how to really get enough strength on the retaining nut while keeping the blades still.
Anyone got a good technique for this?
Thanks.
   / Finishing mower blade removal question #2
You should be able wedge a box wrench on the top of the bolt above the blade, and then use the breaker bar to loosen the nut underneath the blade.
Spray some penetrating oil on the bolt and let it set overnite. If that doesn't work, take a torch and heat up the bottom nut and then try to break it loose.
   / Finishing mower blade removal question #3
I used to block the blade with a 2x4 so it would bind up against the decking, then use a pipe over the wrench. The handle for a floor jack works well also.
Really the best method is air tools though. They'll make life easier for years to come.
   / Finishing mower blade removal question #4
I always used a chain on the blade. Use a wrench and a cheater pipe on the blade bolt. You might need some bigger tools because they are sometimes pretty tough. I changed 60 blades every other day, sharpened them on the off day. Replaced bad ones. I had air tools, but still broke them loose with a wrench. Sometimes air wouldn't get it. So I just broke them all loose with a wrench, since I was gonna need it anyway. Be sure to block it so it won't fall on you.
   / Finishing mower blade removal question #5
Thanks.
You don’t need a real breaker bar, just something that will fit over the wrench handle, and is long to give you leverage (4 to 5 feet is enough). A steel pipe, or something like that - look around your garage and see what’s laying around.
I use this:
   / Finishing mower blade removal question #6
cordless impact wrench is what I use
   / Finishing mower blade removal question #7
My contribution to this comes late - but I'll bet it's the solution.
Some old time finish mower has reversed threads. That is, to loosen them, turn the nuts clockwise.
Old Chrysler products used to have the lug nuts on one side with same reversed threads, but I can't remember which side it was
   / Finishing mower blade removal question #8
^^^^ My Rhino 3 spindle finish mower has reverse thread bolts holding on the mower blades.
And they are not cheap to replace if you hit a stump (errrr...so I have heard :)
   / Finishing mower blade removal question #9
They tightened in the direction that the wheels turned, as I recall. Too long ago to be sure.
   / Finishing mower blade removal question #10
If clearances are tight (no room for a pipe), and you're not too worried about a box wrench, a solid blow to the wrench with a 2-3 pound hammer might do the trick. I have a 4 pound lead hammer that's worked for that without damaging the wrench.
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
