Finishing backhoe build need hydraulic fluid advice
   / Finishing backhoe build need hydraulic fluid advice #1
bdw9862
Hutchinson
Yanmar YM146
I am finishing my towable backhoe build and need some hydraulic fluid advice. I don't know much about hydraulic fluid (or much else for that matter) but am doing my research. As my project doesn't come with "directions" I don't have a recommended fluid. My project utilizes a 6-10 GPM gear pump to run 8 double action cylinders out of a 15 gallon tank.
Thoughts?
   / Finishing backhoe build need hydraulic fluid advice #2
My PowerTrac PT425 uses 10W40 motor oil for hydraulics. My old IH2500b used a universal hydraulic fluid. I'd guess you should first see what you pump manufacturer recommends, though. ;)
Nice looking build, by the way. :thumbsup:
   / Finishing backhoe build need hydraulic fluid advice #3
Some pumps use ATF...fwiw
can't wait to see more pics...:thumbsup:
It is a Dynamic Gear Pump the only thing the website says is Oil Viscosity 6-200cSt and ambient tempature -8 F to 130 F
A few more pics.
   / Finishing backhoe build need hydraulic fluid advice #5
I would recommend a hydraulic fluid with ISO 46 viscosity. Most of your universal hydraulic - transmission fluids today will meet that spec.
Reason for hydraulic fluid is that they contain anti-foam & anti-wear additives designed for hydraulic components.
Case 830 Tractor (A50514)
Case 830 Tractor...
2013 Ford F-550 4x4 Horton Ambulance (A50323)
2013 Ford F-550...
David Bradley Manure Spreader (A50515)
David Bradley...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
