Finishing backhoe build need hydraulic fluid advice
   / Finishing backhoe build need hydraulic fluid advice #1
bdw9862
Hutchinson
Yanmar YM146
I am finishing my towable backhoe build and need some hydraulic fluid advice. I don't know much about hydraulic fluid (or much else for that matter) but am doing my research. As my project doesn't come with "directions" I don't have a recommended fluid. My project utilizes a 6-10 GPM gear pump to run 8 double action cylinders out of a 15 gallon tank.
Thoughts?
   / Finishing backhoe build need hydraulic fluid advice #2
My PowerTrac PT425 uses 10W40 motor oil for hydraulics. My old IH2500b used a universal hydraulic fluid. I'd guess you should first see what you pump manufacturer recommends, though. ;)
Nice looking build, by the way. :thumbsup:
   / Finishing backhoe build need hydraulic fluid advice #3
Some pumps use ATF...fwiw
can't wait to see more pics...:thumbsup:
It is a Dynamic Gear Pump the only thing the website says is Oil Viscosity 6-200cSt and ambient tempature -8 F to 130 F
A few more pics.
   / Finishing backhoe build need hydraulic fluid advice #5
I would recommend a hydraulic fluid with ISO 46 viscosity. Most of your universal hydraulic - transmission fluids today will meet that spec.
Reason for hydraulic fluid is that they contain anti-foam & anti-wear additives designed for hydraulic components.
Land Honor Rock Bucket (A50514)
Land Honor Rock...
Land Hero Mini Skid Steer (A50515)
Land Hero Mini...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
CURTIS ELECTRIC AIR COMPRESSOR (A51244)
CURTIS ELECTRIC...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
