finished homebuilt gin-pole
/ finished homebuilt gin-pole #1
jimgerken
Minnesota
John Deere 3720
I finished my home-built gin-pole. It is shown attached to my (also homebuilt) combination base frame, which will later become a brush-grapple. Neither piece is painted yet, but hopefully will be before Spring. The reach of my J.D. 4100 is now a bit over twelve feet high!, just right for lifting and placing those tall poles next year. I hope this photo attachment works.
/ finished homebuilt gin-pole #2
Nice lookin rig. Just be sure to keep the backside heavy!
Andy in NH
/ finished homebuilt gin-pole #3
Jim,
Nice job! I may want to build one of those too.
Did you fabricate the frame attached to your FEL disconnects?
How about some close up shots of your work?
Terry
/ finished homebuilt gin-pole #4
Nice job! I would also like to see some detail shots if possible. Thanks in advance
Corm
Yea, the peice in this attachment is what the J.D. Loader manual calls a combination base frame, from which they built a pallet mover, a manure fork, a bale spear, etc. Mine will be a grapple. The Pipe top cross member you see is actually 2" heavy pipe slid over 1.5" heavy pipe. The 1.5" is welded in for torsional strength, and the 2" is loose on the 1.5" (it can turn). I am thinking this will make it easy to build the moving (hydraulic) upper jaw of a brush-handling grapple. The lower cross member is 1/4" x 4 x 4 angle iron, but will probably have another pc of the same material welded into it to make it a 4x4 tube, depending on how I decide to attach the lower (fixed) tines of the brush grapple. That is undefined. The attachment to the loader boom matches the J.D. idea, as you can see. I turned the pins on the lathe, and the upper members that look like a shepard's cane, are sawn out of 1/4" x 4" flat iron, with a pc of 1" pipe sections in half and welded in to interface with the loader 1" big pin. It quick-taches just like the bucket. On the front there are also a couple of 5/16" chain hooks.
thanks for the ballasting reminder. I am ordering a box blade today, and will be adding weight to that also. I am thinking I will post a 400 pound limit on the gin pole.
Here's another view.
and a front view of the base frame only on the tractor...
/ finished homebuilt gin-pole #8
Thanks for the details and the picture! I think I have myself a project for spring!
Corm
/ finished homebuilt gin-pole #9
Outstanding work, Jim! /w3tcompact/icons/smile.gif
How 'bout a picture of the Buick you hang on the 3-pt when you use that thing. /w3tcompact/icons/laugh.gif
Just jealous, of course. I gotta get me one of them metal-melting thingies. /w3tcompact/icons/crazy.gif
/ finished homebuilt gin-pole #10
That looks great; a very handy tool. And I'm assuming (fairly confident) that you have enough experience to use it without either turning the tractor over or bending loader arms and such little matters as that./w3tcompact/icons/laugh.gif An inexperienced operator ought to be able to destroy that tractor in short order with the leverage that'll provide./w3tcompact/icons/wink.gif
/ finished homebuilt gin-pole #11
Good point Bird. I am finally getting to the point where when I here that little voice say "this isn't such a good idea" I'm startin to listen. I don't know how many times I heard it just before something bad happened, like that time I was watchin Evil Kneivel on the run up to the Snake River Canyon Jump. Went out, built a ramp and proceeded to launch myself through the air! Well, the best that can be said is I survived, in one piece, although I walked a little funny for a day or two.
Eric
2002 12ft Haulmark KD7X16WT2 Cargo T/A Enclosed Air Cascade Trailer (A66738)
2002 12ft Haulmark...
2007 BIG TEX 20 T/A UTILITY TRAILER (A67714)
2007 BIG TEX 20...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
Ingersoll Rand RT-708J (A64912)
Ingersoll Rand...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
