Finished 3rd Function Valve Project
/ Finished 3rd Function Valve Project #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Then I removed the FEL to give me some working room and connected the three hoses. First the tank hose. I put a running T in the FEL tank line and ran a hose from the new valve tank port into the T at the FEL valve. Next I removed the hose from the FEL Power Beyond output and connected it to the new valve PB output with a short extension hose. And last I looped a hose from the now open FEL PB output back up to the P in port of the new valve.
I put the loader back on so I could see how things would line up and added the qdS to the new valves work ports on top. Not sure I like this but will leave it for now. Might run hoses to QDs on a bulked someday
Then I connected in my grapple lines into the QDs. These lines used to come from the rear remotes so I need shorten these hoses and simplify the fitting hodge podge I have. Then I mounted the handle housing on the valve and attached my lever arm.
Before I started I measured my hydraulic pressure. It was 2450 psi at 1500 rpm. When I finished the plumbing I adjusted the PRV on the new valve downward until I got 2400 psi then went back up to 2450 so they would both be set at the same pressure.
All done and it actually works !!
This was a good project and I learned alot. My first hydraulic experience.
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
25057SFL (A64557)
25057SFL (A64557)
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
