Finish Mowers
/ Finish Mowers #1
Anonymous Poster
Epic Contributor
how much better will a finish mower cut a field than a brush hog...i just got a 3010 and brush hogged my 5 acre field and there is a lot of low stuff left behind...ok but a bit ragged...besides not being able to cut sticks and big berries, what are the trade-offs of going to a field mower vs the brush hog...
/ Finish Mowers #2
A finish mower are used on yards. If you want your field to look like a yard just clear the sticks, etc and mow at least twice with your finish mower, once with the deck high and then down to desired height, so it may take a 2-3 cuttings.
After that mow it as your yard.
Bluegrass, Pick It Up!
/ Finish Mowers #3
brushogs are just what their name implies, they are best when u want to keep brush down or just knock down very tall grass. if u want a more finished look(after the big stuff is down) then a finish mower will be the way to go.u will need to cut a little more often with finish mower. i prefer rear discharge.
/ Finish Mowers
OK, what is the difference in a bush hog and a flail mower, does one give better results over another in finished look?? Also, everyone tells me that a six foot machine, whether it be a bush hog flail mower, or even finish mower, I reckon, will produce a more manicured appearance because it "cuts the tire tracks out" any opinions???
/ Finish Mowers #5
A rotary cutter has one big blade inside a heavy-duty deck, which smashes basically anything in the way, including grass, weeds, saplings, etc. Roughest cut mower there is. The deck and blade are subject to damage from objects you might mow over like stumps, rocks, debris, etc. Can also be used as a regular mower for fields and present a decent-looking cut, though best suited for mowing of tall, high weeds and brush, etc.
A flail mower has 40-100 small, swinging L-shaped blades attached to a shaft, rotating VERY fast, creating a whipping motion of the mini flails... They won't throw large objects like a rotary cutter might, and aren't as subject to damage from large objects like stumps, rocks, and other debris. Personally, I'd say a flail mower works better if you have lighter density/hay type cutting to do on a more regular basis. Flail mower isn't going to cut down the type of brush and saplings a rotary cutter will, but it will provide what I see as a better finish cut, and do it with less noise if that's a factor.
Depending on your needs a rotary cutter might be the better all-around tool, since it too is capable of mowing a field on a regular basis and presenting a respectable-looking cut. This is why the rotary cutters are a much more popular option for compact tractor owners. That and price usually push buyers towards the rotary cutters instead of flail mowers. However, if you're after a clean cut of a field that you maintain, and don't have heavier-duty requirements, the flail mower might be worth it to you.
HTH,
/ Finish Mowers #6
best description of a flail mower i've seen. they seem to be a true "finish" mower.
heehaw
2012 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2012 JOHN DEERE...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
More info coming soon. (A64557)
More info coming...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
PORTA POTTY (A67714)
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
