finish mower
/ finish mower #1
chinawall
My new Woods TK60 finish mower is leaving windrows in its wake. Any suggestions?
/ finish mower #2
The only things I know to do are:
1. Try to cut before the grass gets too tall.
2. Go over the areas of clumping/windrows a second time to help spread out the clippings.
3. Double cut, i.e., only take 1/2 swath on each row.
4. Mow when grass is completely dry, especially if it is tall.
/ finish mower #3
We have an older LandPride FDR1660 and if the grass is 10" or taller, and slightly wet, it will leave windrows. If we take it slower, and cut 2/3 width it does fine. When the grass is dry, no matter what it is a cutting sob and the lawn/fields look great. The mower is 15-20 years old. Still on the original spindles, solid rubber tires instead of the may go flat tubeless.
/ finish mower #4
Cut often and half the width until clean cut.
/ finish mower #6
you'll notice the difference on the deck height between finish & regular brush hogs. brush hogs have a deeper deck height, while finish are rather shallow... that difference is your limitation.
in addition, finish mowers are generally of lighter duty construction.
& keep knives sharp as well, regards
MANIFOLD (A68842)
MANIFOLD (A68842)
2023 CATERPILLAR 299D3 SKID STEER (A65056)
2023 CATERPILLAR...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
2015 HORSE CREEK MFG. FLAT BED TRAILER (A67714)
2015 HORSE CREEK...
