Mowing Finish mower
   / Finish mower #1
cabin kioti
Sullivan County Pennsylvania
ck 30 hst
I am in the market for a kioti finish mower either 3 pt.or belly mower to go on my ck 30. I would need to take the B H off to use either one .I was just wondering if anyone out there has any experience with the cutter.Thanks ;) ;)
   / Finish mower #2
I have the 72 inch kioti italian made rear finish mower.It works acceptably. I considered the mid mount as I was upgrading from a garden tractor. The final decision was the want to not have to wrestle a heavy mid mount deck in and out of place. I imagine its like a riding mower deck removal and install except a hundred and some pounds more.
Then I considered the usefulness on my own lot of being able to back the rear mower deck into places one couldnt get with the mid mount and being able to lower the running deck down onto brush and tall grass back there.
   / Finish mower #3
i have the 60"rfm, cant tell you about long term durability but i can say that it cuts good,the only thing that i dont like is the retaining pins,lost two of them already have only had it for 4 months,dont like the little steel loop thats supposed to keep it from falling out of the main pin,i have replaced them all.
i mow about 4 acres and alot of its pretty rough so it gets a shakin....chris
   / Finish mower #4
I have a Woods RD-6000 which is a rear discharge finishing mower. I had this mower prior to the purchase of my Kioti, CK-35-HST and use it weekly if not more often, cutting about 4 acres. In my opinion Woods make the best mowers on the market although I have heard excellent reports on the Rhino as well. My two cents worth, Ron.
   / Finish mower #5
The only times I had that happen is when I backed the mower into stickers, etc and the pins got caught. It looked to me like one could cure that by either using traditional tractor pin retaining pins or large cotter pins.
   / Finish mower #6
TL we use 1/4" bolts and double nut them.
But that only works if you don't adjust ht often or you don't mind grabbing a wrench if you need to.
I like the rear mount mower.
Mid mounts are brand specific and are a pain to take on and off.
More costly too.
Unless your tractor has a woods hoe on it you can't run a mid-mount with a hoe anyway.
KO
   / Finish mower #7
I had a belly on my last tractor and switched to a rear. There are advantages and disadvantages to both, but the MMM is a pain in the butt to keep taking off everytime you do FEL work, driveways, etc. The last one I had had four wheels on the mmm but only two would rotate, the other two were fixed, so if you don't have alot of room or a lift system, you will be swearing every time you remove it.
The RFM took a little seat time to get used to. I getting a bigger one here shortly.
   / Finish mower #8
I just bought a new Kioti CK20HST with a BackHoe and a front loader, and I first asked the dealer to put a belly mounted mower.
Before he delivered the tractor he just called me and asked if I was to have the mower on for the entire season of if I will have to mount and dismount the mower eache and every week or so. When I said that it will be almost everyweek because I will need the BackHoe very often, He told me that I will HATE him very soon with a belly mower and he sufggested me to have a rear mower and that it was cheaper.
I appreciate the fact that he called me prior to deliver the tractor.
My two cents
Denis
   / Finish mower #9
It looked to me like one could cure that by either using traditional tractor pin retaining pins or large cotter pins.[/QUOTE]
Exactly:
   / Finish mower #10
I always thought the Kioti belly mower was a rip off in addition to being essentially incompatable with the backhoe subframe. Don't even dream of getting a MMM if you have a Kioti backhoe subframe. That is an afternoons work to take off and remount.
I had the Rhino 60" rear discharge mower on my CK20, great mower for the limited time I had it. Mine was used but in fine condition and worked very well.
Having said this, I am now converted to flail mowers. They cut like a finish mower but are just about as tough as a bush hog and are much shorter than rear mowers so are more manuverable. I have the Caroni TM1900 on a DK40se and that one is too big for the CK20 but the TL1500 would be a nice match for the CK20. I think a CK30 would run a TM1900 like I have very well. Might be slower in bush hog mode but would do just fine as a finish mower. Quieter than even a finish mower too.
Third photo shows big chunk of metal debris wrapped around mower...took a few minutes to peel if off and then kept on mowing. No damage.
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
2004 International 7500 T/A Rolloff Truck (A50323)
2004 International...
Steel Flatbed (A50515)
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2014 Chevrolet Cruze (A50324)
2014 Chevrolet...
