Mowing Finish mower
/ Finish mower #21
With regard to my metal frame incident with the Caroni flail, here are a few more photos. I don't think the frame was laying on the ground but was partially buried. The mower must have caught a section sticking out of the ground then ripped the whole frame out from under the turf and immediately wrapped it around the mower drum. Obviously it stalled the tractor. I got off to check and cringed when I saw this quite substantial though rusty length of angle iron disappearing into the mower. I disingaged the PTO, restarted and lifted the 3pt to have a look. I saw the metal twisted around the drum but no damage to the mower. Put my gloves on and started yanking on the angle iron while counter rotating the drum with my other hand and after a 5 minute battle got the metal off. That was it. It has mowed just fine since.
I've also shredded into confetti what I think was an old rusty car fender, chewed up half of several car tires (smelly process) and even backed into and took a few whacks at an old gas station pump laying in the weeds :eek: before I could stop. No problem.
On reflection I am not that surprised that the mower seems to survive these incidents without harm. After all highway departments use big flails to mow medians and curb strips and they undoubtedly hit all manner of heavy junk. What did pleasantly surprise me were that 1) the Caroni flail despite costing much less than half of what the "highway" flails cost seems to stand up to at least moderate abuse with no trouble and 2) that the cut is substantially better than what you get with a bush hog rotary style cutter. When I used a rotary cutter to chop up brush, the land would be covered with 3-6 inch size sticks and chunks of debris. With the flail that is all mulched into something the size you might get out of a chipper/shredder. For mowing a pasture and possibly anything less fussy than a golf green or a prim suburban lawn it does a great job. I should be clear that I have the TM1900 which has the heavier duty style blades/hammers so the TL style with double the number of lighter weight blades probably is less robust but would give an even better cut. Finally (3), I don't have to worry about slinging rocks and sticks at houses or pedestrians. I have also come to appreciate the substantially shorter length of the mower which means less scalping and also makes manuvering and storage much easier.
I don't know why "moderate duty" flails are not more commonly used except that only Caroni, an Italian company with what appears to be only one distributor in the US, sells them for prices that are directly comparable to the cost of a decent finish mower. Most flails cost two or three times what a finish mower does. For moderate duty bush hogging and pasture cutting I prefer this to a my Bush Hog rotary cutter and I don't have any need for a finish mower any longer.
/ Finish mower #22
I really like those flail mowers as well.
One advantage of a mid mount mower is that you can do two things at once. In my case, I can mow while I tow the sprayer on a small fruit farm. Time is money and so if I can do two things at once, I am ahead of the game.
Everything bad about mid mount mowers is right on the target and add getting stuck if you happen to need to go into the woods or something and pass over as stump. Not that that ever happened to me!
/ Finish mower #24
I am a New Zealander and have had some experience with Trimax mowers and can tell you that they are a very good machine. They had good back up in NZ as it is their home market, but I am sure that they will be doing their best in the US as well.
/ Finish mower #25
What do ya'all think an ok price would be to ask for a 2005 72" Kioti used rear finish mower with about 30-35 hours on it in nice, kept indoors shape??
I want to get the flail...Agrisupply says 1575.00 for the Caroni 75inch plus a (killer) 581.00 for shipping to 98166
I can see where this would be a better rig on the terrain I mow--the dealer i used to buy the tractor certainly didn't discuss any mower options other than brush hog and finish mower.
/ Finish mower #26
I wonder what an ok price would be to ask for a 2005 72" Kioti used rear finish mower with about 30-35 hours on it in nice, kept indoors shape??
/ Finish mower #27
I want to get the flail...Agrisupply says 1575.00 for the Caroni 75inch plus a (killer) 581.00 for shipping to 98166 quote]
Paradoxically, that "Kioti" finish mower you have was built by Caroni! If you don't need to sell it immediately, I'd try to get $1200-$1300 for it anyway as a new one costs at least a few hundred more than that. Those are excellent mowers but they don't have the name recognition of Woods, Rhino, Bush Hog, Landspride etc. Still, with those "premium" brands now selling for $1800 or so, you shouldn't have much trouble finding a buyer.
Man, that shipping to the west coast hurts! :eek: Consider that payback for all the A/C and heating you don't need to pay for that the rest of us do.;)
I wouldn't be too hard on your dealer. Flails are generally thought of as very expensive industrial type machines. Caroni is one of only a small number of companies that are producing flails that would be of practical use for a typical CUT owner. As you have discovered, AgriSupply in NC is the only importer so far. Given the extremely expensive shipping charges, you might want to look locally to see what a flail might cost. There is also a guy on eBay that seems to be selling a Chinese manufacturered flail and if I am not mistaken I think he is based in Washington or at least on the left coast. No experience with that Chinese flail but if he's close you might be able to take a look. His prices were good as I recall.
/ Finish mower #28
If you have a Kioti KRM 72 RFM it is made in Italy by a company by the name of Sicma.
I have seen them go on ebay for over 1000 used.
BUT, YMMV.
The best thing to do would be sell it in the spring.
I know all of the details on the ebay mower because I sold it originally. LOL
It actually sold used on there for more than I sold it to him new.
How's that for resale value!
He bought it before steel started it's upward climb.
BTI
/ Finish mower #29
BTI said:
If you have a Kioti KRM 72 RFM it is made in Italy by a company by the name of Sicma. BTI
Are Sicma and Caroni related? Someone else (another dealer) mentioned that Caroni built at least some of Kioti's mowers.
In any case, the Italian implement manufacturers seem to put out quality equipment.
/ Finish mower #30
IslandTractor said:
I have the Caroni TM1900 on a DK40se finish mower too
Great metal working capabilities with the flail :~} is yours the TM1900FSC?
I would like the finer cut feature of more flails...noticed theres 3 different varieties on their site, judging in my best interpreted Italian.
/ Finish mower #31
I think that is correct. It is the one with three belts rather than two and with about 50 vs 90 or so flails. The flails on mine are the "heavier duty" style but not technically the "hammers" that you see on some industrial strength flail mowers. The cut I get in pasture is about as good as the cut I used to get with a Rhino finish mower. I'm sure you'd need a finer set of flails to cut a golf course green but they do a pretty fair job of lawn cutting for what they are.
/ Finish mower #32
On the Finish mowers, it all depends on what year it is.
The sicmas have been used since at least 2001.
I know this because they are the only ones I've ever had in stock and we started business in 2001.
I do believe that Caroni made some of the ones used before 2001.
I agree on your assessment of Italian equipment.
We have had very little trouble with the units.
As with any finish mower that uses spacers and lynch pins to adjust the height.....
Take out the pins and replace them with 1/4" bolts and double nut or use a nylock on them.
We sell quite a few wheels and forks and spacers........
BTI
/ Finish mower #33
County Sawyer said:
I have a Woods RD-6000 which is a rear discharge finishing mower. I had this mower prior to the purchase of my Kioti, CK-35-HST and use it weekly if not more often, cutting about 4 acres. In my opinion Woods make the best mowers on the market although I have heard excellent reports on the Rhino as well. My two cents worth, Ron.
I have this mower as well. i purchased it in the spring and can not express i much i love it. On and off is so simple, no sliding a mower deck in and out and no sliding under the machine to hook anything up. I also LOVE the rear discharge... no windrows of grass anywhere. I does a beautiful mowing job as well.
/ Finish mower #34
I notice the Caroni flails are sold with the option of number of flails. They show using more for finer finish type cut, according to their website.
/ Finish mower #35
That is correct. Caroni makes about 25 models of basically the same mower in three or four widths and various numbers and types of flails. However, I believe that the US importer, Agrisupply, just brings in about 3 or 4 variations on the basic theme. I don't think you can get the high quality finish version in the 75 inch size in the US and similarly you cannot get the tougher TM version in the smaller sizes if I remember correctly.
Again, I find the "tough" version I have has a cut that I cannot distinguish from my former Rhino finish mower but I am talking about pasture cutting not a fine lawn.
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
(4) 29/11-15 Dirt Track American Racer Tires (A64127)
(4) 29/11-15 Dirt...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
John Deere 1025R (A62177)
John Deere 1025R...
