Finish mower vs bush hog?
   / Finish mower vs bush hog? #1
artp
Southern Illinois
Kioti CK30HST
I am going to replace a Ford 1210 & 4 ft Model 936A finish mower with a new tractor and rear cutter. I am looking at 28-30 hp tractor to match up with the new cutter. The property is approx 4 acres of generally flat to small rolling hills of mostly open pasture with some out buildings, ect to cut around, nothing severely steep-just rough grass to cut- a few low spots that can get a little wet. I like the look the finish mower gives, but I am wondering how well a new finish mower will hold up? The pasture is very visible from the house so the finish look is appealing (my wife's input here). How much should I expect to pay for a good quality finish mower vs the bush hog? Dealers in the area are quoting between $700-1400 for 5ft bush hogs (Land Pride, Rhino,ect)-good match for my situation? I don't have any experience here expect for the 936A for a finish mower. I don't know how it compares in quality vs the newer finish mowers. I would appreciate input from forum members. Thanks for all the great posts!!!
   / Finish mower vs bush hog? #2
You might be able to get by with just a RFM, but you would certainly have to mow more frequently to keep the growth from getting ahead of you. I have used a 5' Sitrex rear finish mower for 6 years behind a Kubota B-2710 and I love it. I normally just use it for mowing the lawn areas but have on occasion mowed around a field to maintain a walking path. I also have a bush hog (KK brand) and it handles heavier growth with no problems. It probably comes down to finances - if you can't afford 2 implements then the RFM will do the job - you might have to go a little slower and more often. If you read the L&G posts there are a number of folks that use L&G tractors to mow fields and pastures that probably should require a bush hog but they get it done. Good luck with your purchases. NOTE: don't know the current prices for Sitrex but mine was around $900 new in 2002.
   / Finish mower vs bush hog? #3
A 30hp machine should pull a 6' finish mower. You can likely expect to pay about 1500$ for a 6' one.. ot about half that for a 5' hog.
pasture? I'd hog it and save the money. That way if the grass ever shot up 2' you'd be ok, and not burn up your 1500$ finish mower trying to brush hog with it..
soundguy
Thanks for the quick replies guys. I really appreciate the fine posts on this forum. I don't know when Dad bought the Ford 938A finish mower, but it was many, many years ago. The only thing he ever did was just regular maintenance. He always kept his equipment in great shape. It still runs, but like you said when the grass gets away from you, especially with the very wet spring we had in Southern Illinois, it can be really tough on the equipment. Still leaning toward the RFM (please the wife, but me too). Will check around on prices. One more thing to decide for my new tractor setup. Lots of work, but fun too. Just trying to pick up good info before I put the final package together.
   / Finish mower vs bush hog? #5
Remember... a rough cut mower with a sharpened blade will cut nearly as good as a rider lawn mower.. perhaps just a bit shaggier.
soundguy
   / Finish mower vs bush hog? #6
You might want to read up on the Caroni flail mower also. JC
   / Finish mower vs bush hog? #7
I had a Land Pride Air Tunnel finish mower I pulled around with my JD650, did a real nice job on the pastures. Always said the lift suction was strong enough to suck a golf ball through a garden hose. Mower was built really strong and quite frankly if it went under the deck I cut it, yea to some extent I used it as a brush hog. Let's face it, pastures should never get to a height of two feet or one foot for that matter.
   / Finish mower vs bush hog? #8
soundguy
Ditto- Jay :)
   / Finish mower vs bush hog? #9
How about a few sheep or goats?:D
I cut with a 5' hog - the worst of it is that the corners dig in when turning, ends up plowing chunks of sod up. I have to lift before turning - sometime i will get around to putting double (corner) tail wheels on it:eek:
I does do a good cut though - i put a sharp edge on it and it cuts fine. The finish mower will have better lift than the hog - if your grass is a little to long then it won't stand back up after driving over it and the hog won't lift it very efficiently.
Cheers,
Mike
   / Finish mower vs bush hog? #10
A couple points,
A good finish mower needs 4 wheels, one on each corner, so it can follow the contour of the land, it will be like towing a trailer.
Side discharge works best for me. If the pasture got away from me I could always run through again and windrow the cuttings for easy pickup.
Deep deck design works best for pasture. I think my Land Pride had a 6-inch deep deck. I could mow at 4.5 inches and have room under the deck for 10.5-inch high grass to stand up to be cut. And remember it takes far, far less time to mow, say 8-inch grass than it does to cut 16-inch grass, the higher the grass the more weeds you'll have, high grass that has been cut and laying on the pasture does not promote good pastures.
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2018 Mac 48FT. T/A Walking Floor Trailer (A51692)
2018 Mac 48FT. T/A...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2025 CFG Industrial H15R (A50123)
2025 CFG...
