Rear Finish Mower Finish Mower - sharpening your blades
   / Finish Mower - sharpening your blades #1
duffer
Platinum Member
Aiken, SC
'16 Mahindra 2538
Happy Memorial Day everyone, and especially all those who served, and those that gave their all for us. :flagday:
Have a 3 blade finish mower (PTO). I mow 10 acres about every other week or so, depending on rainfall.
Would like to hear from you finish mower guys how often you sharpen your blades, and the process you use. I've looked on YouTube and everybody does it differently.
Do you sharpen the front of the blade and remove burrs on the back? Front side only, back side only, etc?
I seem to be sharpening mine a lot, which makes me think I may not be using the correct process to sharpen them.
Thanx!
   / Finish Mower - sharpening your blades #2
Once ran a Scag zero turn that had 3 blades. Used the same process as I use on my walkbehind lawn mower blades: Sharpen the intended side with the deep bevel, counting the # of times I run the grinder wheel down each bevel and do the same # on each side of the blade. Then turn it over and do the back side lightly, mainly to remove high spots.
If blades end up with some deep nicks, grind down perpendicular to the blade and then do your normal sharpening. This is what I often have to do on my bush hog blades. Of course, I never really "sharpen" them.
Ralph
   / Finish Mower - sharpening your blades #3
Angle grinder with a low grit flap disc. Once you get the blade edge back to where you like it, sharpen often with a high grit flap disc to maintain the edge.
More frequent higher grit sharpenings will surprisingly help your blades last longer.
   / Finish Mower - sharpening your blades #4
I also use an angle grinder with flap disc. Generally 60 grit to maintain an otherwise good blade. I get the 30 degree edge, then run the flap disc lightly down the backside to debur.
I recently bought a jig that I strap my angle grinder into. I was surprised how far off my angle was after a few dozen sharpenings without a jig. The jig wasn't cheap ($149), but I'm really glad I spent the money on it... It's a mom and pop operation called Yellow Hornet. This jig will only work with flat blades, not the wavey mulching style.
Anyway, I mow about 25 acres per week, and sharpen the blades every 2 weeks or so.
   / Finish Mower - sharpening your blades #5
Multitool belt grinder. Fast without burning. Be sure to blunt the cutting edge about 1/32” after sharping. Blades will stay sharper longer without a knife edge.
Switched to Oregon G5 blades from originals helped on Woods RD7200.
   / Finish Mower - sharpening your blades #6
I mow about 3 acres 3-5 times in spring with JD L120 (three blades - 48 inch deck) and sharpen by eye and try to balance them at leas once each mow season...... About ten minutes into mow after sharpening them I find a rock.... So long sharp blade.....
Dale
   / Finish Mower - sharpening your blades #7
I’ll second the Oregon G5 blades. Hold an edge much longer and the lift is decently stronger than stock blades
   / Finish Mower - sharpening your blades #8
I also use an angle grinder with flap disc about every 4th mowing I touch the blades if I don't nick rocks or road side sand etc.
   / Finish Mower - sharpening your blades #9
I sharpen my blades when they need it and scrape the deck whenever the mower starts leaving streaks or uncut tufts while driving at full speed. I have sandy soil so the blades get sandblasted paper thin every 1-2 seasons. If I dont hit any hidden land mines like rocks or branches then I find the blades hold their edges for a good while. Keeping the deck clean and avoiding wet grass goes a long way.
I take the blades off the mower and sharpen them to a razor sharp edge using a 80 grit flap disk on an angle grinder.
The gator blades work well and lasted twice as long as the standard high lift blades. Ive switched back to the high lifts because the leave less clumps and are better for clearing leaves in the fall.
   / Finish Mower - sharpening your blades #10
No one uses a benchtop grinder? Is this because you are sharpening them on the mower?
Anyway, since Oregon products were mentioned here, they have a web page for sharpening: Lawn Mower Blade Sharpening How-To Guide | Oregon Products
I cut 9 acres quite often, I sharpen when the grass isn't getting cut correctly (uneven/highpoints). I first tend to notice this when turning, when it starts regularly happening when going straight it is time to sharpen. I hate sharpening, because I take the blades off and they can be a bear to remove, plus I have to get out multiple wrenches and blocking. I also tend to inspect the bolts, lube them after hitting them with a wire brush, and the build up on my blades gets cleaned off (plus wd-40 or fluid film). I also scrape down my deck. I also pressure wash my deck at least 2 times a season. I didn't pay 3k for a mower deck to see it trashed. I do about the same thing with my zero turn. Since I use both pieces of equipment (7' RFM and zero turn, it spreads the abuse across the two implements).
New/Unused 20ft x 30ft x 12ft Storage Shelter (A44391)
New/Unused 20ft x...
1989 Ford C8000 Bucket Truck w/ CAT 3208 Diesel Engine and 1800 Gallon Water Tank (A44789)
1989 Ford C8000...
2017 MOROOKA MST 150”VD (A45046)
2017 MOROOKA MST...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A44391)
IMPORTANT PLEASE...
2022 Mack MD Danco 12SR22 22ft Rollback Truck (A42742)
2022 Mack MD Danco...
YANMAR VIO17 MINI EXCAVATOR (A45333)
YANMAR VIO17 MINI...
