Rear Finish Mower Finish mower, rear vs. side discharge
   / Finish mower, rear vs. side discharge #11
I may be a little late in this post but here goes anyway. I mow aprox 5 acres with a rear discharge Bush Hog and experience tell me that dry grass does not clump as bad and with the rear chain guards removed it looks as good as any riding mower. No clumps no wind rows.
   / Finish mower, rear vs. side discharge #12
How high do you have your cut height set?
   / Finish mower, rear vs. side discharge #13
One thing I've found that helps any mower is to clean the underside thoroughly and then spray on a couple coats of EZ Slide, which is a slick coating we used on the farm for gravity box wagons. I'm sure there's an equivalent at your local farm supply store. At any rate, it helps keep the wet grass from sticking to the underside of the mower deck.
Rick
(4) SETS OF 5" CASTOR WHEELS (A57192)
(4) SETS OF 5"...
2020 JOHN DEERE 245G LC EXCAVATOR (A52707)
2020 JOHN DEERE...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A57192)
2019 CUSHMAN...
2012 Ford Fusion Hybrid Sedan (A55853)
2012 Ford Fusion...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
