Finish mower PTO issue with Quick Hitch
/ Finish mower PTO issue with Quick Hitch #1
Jeepnford
NE Missouri
Case DX35
I have a Bush Hog RDTH-72 finish mower I'm trying to use on a quick hitch. The problem I'm having is the lift pin brackets "float" up and down about 4 inches or so. When the pins are up there's plenty of clearance. When the pins are down the PTO cover rubs on the QH. I have a top link adapter on it. I was thinking about drilling and putting a bolt so the lift pins on the mower were fixed in the up position. Would that cause issues with the mower following ground contours or other issues?
/ Finish mower PTO issue with Quick Hitch #2
I had the same problem with my 72" Farm King mower. I did 2 different fixes. One I notched and reinforced the top cross piece of the quick hitch so that the pto shaft had a few more inches of space. Secondly the lower arms on the mower had stops welded onto the mounting slot so that they could no longer drop to the bottom of the slot they were mounted in. The lower arms could still move up and down but no longer had the factory range of motion. I never experienced any problems with that modification.
/ Finish mower PTO issue with Quick Hitch #3
Does it rub hard enough that the guard pushes into the PTO shaft?
I'll probably try to restrict the range of the lift pins first, then modify the QH if needed. I haven't seen one up close yet but I believe on the new model Bush Hog finish mowers the lift arm pins are fixed.
2013 PETERBILT 587 DOUBLE SLEEPER ROAD TRACTOR (A60430)
2013 PETERBILT 587...
UNUSED RAYTREE RMA42 HYD AUGER (A60432)
UNUSED RAYTREE...
New Holland C327 Two Speed Compact Track Loader Skid Steer (A59228)
New Holland C327...
2017 WEILER P385B ASPHALT PAVER (A60429)
2017 WEILER P385B...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A60432)
UNUSED AGT...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
