Rotary Cutter Finish mower or rotary cutter
   / Finish mower or rotary cutter #21
I mow a few small fields around our house.... using our 8N (approx 24 pto/hp, 9N around 20 pto/hp).........the old timers around here were evenly divided between a 4' & a 5' being the optimal size for a N tractor. ......Now having many hours mowing behind me I would have definitely bought the 5' .......
This is solid gold advice. There is nothing like actual experience. The statement by others that a finish mower can be wider than a rotary is only true if the crop is an easy cut. But fields sometimes "get away" and grow tall. If all you have is a high-speed mower on an under powered tractor - it's a tough situation. The rotary will at least lay it down without working that 9n senior citizen to death.
Thanks again for all the input. I was leaning toward a finish maower and found a good deal on one. I'll keep the swisher rough cut in case the place gets out of hand. I plan to mow at least every two weeks so the finish mower should be fine. More than likely, I'll mow every week. Thanks again!!!
2013 TYTAL CRUDE TRAILER (A58214)
2013 TYTAL CRUDE...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
Toro Workman HD Utility Cart (A56857)
Toro Workman HD...
