Rotary Cutter Finish mower or rotary cutter
   / Finish mower or rotary cutter #21
I mow a few small fields around our house.... using our 8N (approx 24 pto/hp, 9N around 20 pto/hp).........the old timers around here were evenly divided between a 4' & a 5' being the optimal size for a N tractor. ......Now having many hours mowing behind me I would have definitely bought the 5' .......
This is solid gold advice. There is nothing like actual experience. The statement by others that a finish mower can be wider than a rotary is only true if the crop is an easy cut. But fields sometimes "get away" and grow tall. If all you have is a high-speed mower on an under powered tractor - it's a tough situation. The rotary will at least lay it down without working that 9n senior citizen to death.
Thanks again for all the input. I was leaning toward a finish maower and found a good deal on one. I'll keep the swisher rough cut in case the place gets out of hand. I plan to mow at least every two weeks so the finish mower should be fine. More than likely, I'll mow every week. Thanks again!!!
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A58214)
2012 TROXELL...
401 (A52706)
401 (A52706)
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2009 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
