Finish Mower Mods
/ Finish Mower Mods #1
GaryE
Platinum Member
Winterport, Maine
L3710 GST
After a very rainy spring and then spending a few weeks out of town, I found my fields were some what over grown. Not to worry, I just upgraded from my B-6000 to my L-3710. The woods RM-59-1 ( I think) would handle the job just as it did in the past. I just needed to replace the blades due to the difference in PTO rotation direction. With the added PTO HP of the 3710, this should be a piece of cake! Or so I thought.
The first pass I noticed the new belt I just installed was smoking. So I stopped. Found the grass was wrapping around the spindles. So I got out my knife and cut it lose. Figured it was just a fluke, when my B-6000 got in grass to high, it just bogged down. So I went at it again, throttle up to PTO speed and here we go....... Same thing, but now it threw the belt. See attachment.
Houston, we have a problem.....
It seems with the added HP the engine does not bog, but the deck just slips, stops cutting and then just wraps itself to death. This is not good.
/ Finish Mower Mods
So I call my local Wood's dealer and ask if there are some type cups or guards for the spindles, they tell me NO.
So I run out to my local steel supplier and get 3 pieces of schedule 80 pipe and 3 pieces of 1/8 steel plate and go at it.
/ Finish Mower Mods
A little welding, cutting, welding, grinding.... problem solved. Worked like a charm!!!!!
/ Finish Mower Mods #4
If I see one more good reason for me to get a welder....
Nice job! /forums/images/graemlins/cool.gif
/ Finish Mower Mods #5
Gary , Great job! good fix for a repeating headache..You must not have a bushog /forums/images/graemlins/grin.gif
Did you sharpen blades while you had them off?... /forums/images/graemlins/wink.gif
/ Finish Mower Mods #6
Good idea.... /forums/images/graemlins/grin.gif
Does spinning that cup cause any excess vibration while mowing?
/ Finish Mower Mods
<font color="blue"> You must not have a bushog </font>
No, but after throwing the belt I was ready to go get one! This was a lot cheaper!
/ Finish Mower Mods
<font color="blue">Does spinning that cup cause any excess vibration while mowing? </font>
I was worried about that when I started. I was very careful to make sure the cup was centered and as ballanced as I could make it. To my surprise, no vibrations. I think the spinning mass is so close to the center of rotation a little bit of unballance is not t big deal. Got lucky /forums/images/graemlins/cool.gif
/ Finish Mower Mods
<font color="blue"> If I see one more good reason for me to get a welder.... </font>
Where else are you going to rest your welding helmet?
/ Finish Mower Mods #10
Gary, I have a RM-48 that went through a change of rotation also. I didn't know it was a reverse unit when I bought it and the blade bolts would not stay tight. Fortunately I had a junker that was other wise the same but correct rotation. Swapped the spindles and was OK. The bolts for the correct rotation are left hand threads.
/ Finish Mower Mods
Edward,
This unit must have started life as a "correct" rotation. The bolts in the spindles are left hand thread. I did not know they used different spindles... makes sense.
Guess I was lucky they never came lose. I always tightened them down with an impact wrench, so that may have helped.
My fear is after turning in one direction for so many years, the bearings / bushings will fail soon spinning the other way.
Gary
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2011 Ford F250 Super Duty Lariat (A66408)
2011 Ford F250...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
Meteer 6R Corn Head Reel (A66408)
Meteer 6R Corn...
