Tires finding wheels for an L225
/ finding wheels for an L225 #1
Beaverplt
Sussex, WI
Kubota L225
Hi, I have a problem with the rear wheels on my L225. The rims have rusted out and need to be replaced. I haven't been able to find any. I have a feeling I'm not looking in the right places. Any help will be appreciated.
/ finding wheels for an L225 #2
Finding wheels for the L225 is not simple, especially if it has front wheel drive. Front and rear tire diameters need to be the right ratio. The L225DT owner's manual showed 16" rear rims with tall-rib ag tires. Many had turf tires. When my L225DT needed a rear wheel, I found a 16" John Deere implement wheel that was nearly identical. The bolt holes needed to be slightly reamed out to slip on. Not ideal, but it worked. If your machine is 2wd there may be more rear wheel/tire options because they're independent of the fronts.
Mine is a 2WD with liquid/air filled turf tires. I'll keep looking for a while and keep in mind your experience with a John Deere wheel. If there's any good news in this, it's that I need to do a brake job on it. This will be a good time to add that to the project list. BTW, you should see what the fluid that ran out did to my lawn.
Interesting update. According to TractorData.com the rear wheel size for the L225 is 9.5-24. Mine are 13.6-16.
/ finding wheels for an L225 #5
Same tractors can have different rims depending on the tires mounted.
Ags might be one size while turfs another.
The rolling distance (circumference) is what counts especially for a 4 X 4.
Generally turfs will be wider and hence fatter thereby wanting a smaller rim than ags which generally are narrower.
Considering it's 2WD, I don't care whether I use Ag tires or turf tires. At this point, easier to find is going to be the way I'll go. Finding a turf tire and rim might be cheaper because I'd only replace one, but if I can't find the rim, I'll look for Ag's.
/ finding wheels for an L225 #7
Beaverplt,
Did you consult your local Kubota dealership? It looks like the wheels are still available, but at a significant cost.
Looking at the parts listing on Kubota.com, it looks like there are different p/n's for left and right hand side. Not certain why, but that is the way they are listed.
34209-27910 LH ASY 9,5X24R1 $589.10
34209-27990 RH ASY 9.5X24R1 $818.85
The picture with item numbers on Kubota.com is very difficult to read, so it's possible I'm reading it incorrectly and suggest you verify yourself.
I'm hoping to find used. $1,400 for new wheels is a bit steep for me.
/ finding wheels for an L225 #9
How bad are they rusted? I welded up my neighbor's tractor wheels to repair rust around the valve stem and a few other areas due to corrosion (calcium filled wheels without tubes). Some of the patches were several inches in length /width. Held up for 5 years now. Look ugly but functional.
Fully agree the wheel price is crazy expensive. I bet that if you measure the mounting dimensions, it might be possible to match up with a newer tractor model.
Did you see the p/n (34209-27900) for the wheel assembly in the photo provided in the earlier link? Sometimes it is cheaper to buy the wheel and tire from Kubota than the tire alone. Couldn't verify the item number (023) in the photo to confirm it was the AG tire/wheel. Might be worth investigating though. Keep in mind it is often more economical to purchase complete tire/wheel assembly from wholegoods (sales side) versus going though parts.
Long shot...
M7040SUH/SUHD uses a 9.5-24 R1 for the front tire. Order Code AMR8955C with a suggested List price of $459.00 This is for the wheel and tire mounted ready to put on your tractor. You'll need to research the bolt pattern and other mounting info.
Where the wheel rusted through is on the inside of the wheel. It's a long section about 20" long and maybe 2" at it's widest. I won't know until I get it off how bad the rest of it is. Unfortunately, I have to finish a complete exhaust overhaul on my brother in law's Ford Escape to make room to get the tractor in the shop. Until then, I'll just have to start calling all the implement dealers in the area looking for a used one.
/ finding wheels for an L225 #11
I realize this is an old post but I thought I'd reply with a solution that worked for me incase anyone else has this issue in the future. The L225 was only made for a couple of years and I too found replacement 9.5x24 wheels impossible to find. I found some 10x24s on eBay however for $150/ea shipped that work perfectly. The only minor issues are that the eBay rim is silver in color and I had to buy some grade8 5/8"x3 1/2" bolts, nuts and washers to make it work. The Kubota wheel-centers fit like a glove. The rim was item #381840869095 and advertised as "Tractor Wheel Rim 10 X 24 for International Farmall Massey Harris Allis Chalmers".
I put some pics here: Update your browser to use Google Drive - Drive Help
Amazingly, I found two of the exact wheels with tires on Ebay from a place out of Tennessee. I only needed one, but bought the pair so I have a spare.
/ finding wheels for an L225 #13
Know this is an old post, but I had exact same issue with my L225. I have no welder, but cut a piece of metal, and used good old JB Weld to cover the rusted out hole. Also used rust encapsulator on all rust. then painted with new orange paint. Been working for last 2 years with no problems. Also replaced the tube. Made sure no water was in the tubes for ballast, which I suspect caused the original rusts.
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A64553)
2025 Vicsec 30in...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
UNVERFERTH GW-530 GRAVITY WAGON (A64278)
UNVERFERTH GW-530...
