Finding soil bearing capacity?
/ Finding soil bearing capacity? #1
IHDiesel73L
Can anyone tell me how I can find the bearing capacity of my soil short of having an engineer actually test it? I need to know how many piers/what size I will need to support my new building. I pulled an NRCS soil report on my area and the soil taken from test holes I dug at the building site matches the description:
AnoC2 - Annandale Gravelly Loam
Depth to restrictive features: 18-30" (I have dug to 48" without hitting large rocks)
Seasonal high water table: >60" (it's about at the surface right now, hence concrete piers rather than posts in the ground)
Potential frost action: Moderate
Drainage class: Well
What I can't seem to find out is what this soil will support. 2000lbs PSF? 3000? etc... NRCS is checking for me but their engineer is out today. I thought about trying to do my own test by testing how much weight PSI it will support by rigging up a way to place a controlled amount of weight on a 1" x 1" stake. Soil that can support 3000lbs PSF should also be able to support about 21lbs (3000/144) PSI right?
/ Finding soil bearing capacity? #2
Google "Cone Penetration Test"
Or call your local building inspector.
/ Finding soil bearing capacity? #3
If you use 2000psf you'll be fine. Really crappy soil can be as bad as 1000, the best you'll get out of rocky/gravelly drained soil is about 6000psf.
Your test with a 1" stake won't work because it's too small. You might land on a rock or you might end up where some dinosaur took a crap. Also what matters is the soil at the depth of the bottom of the hole. So if you have a 40" frost line, you have to do the sample at 40" and below.
After doing some reading on the topic I think 2000 might be a good estimate given the conditions. There is gravel present, but there is also a fair amount of clay and silt mixed in, and it's fairly wet due to the high water table. I plan on using Bigfoot footings as the base of 8" piers. 10 piers with 24" bases will give me 31 SF of footprint/62,000lbs of support in 2000lb PSF soil. I suppose it could be better than that, in which case I have a pretty good safety factor :thumbsup:
/ Finding soil bearing capacity? #5
Your loam is a compressible material, not suitable for supporting a building or even a driveway slab. You have to strip all that off first. There is no substitute for a density test except a SWAG (S is for selective not scientific) which may or may not be accurate. Reputable builders will do the test and get the engineered solution.
Ron
/ Finding soil bearing capacity? #6
Can anyone tell me how I can find the bearing capacity of my soil short of having an engineer actually test it? I need to know how many piers/what size I will need to support my new building...
Typically, piers do not support a load by bearing on the bottom end of the pier. The support is from friction on the sides of the pier.
You need to have a soils engineer look at the soil and an architect or a mechanical engineer design the building and the piers.
You may think this is expensive and unnecessary, but it will be money well spent. They will save you the expense and problems of an unstable building, and the architect will be able to design something you can build yourself and save that way, if you tell him this ahead of time.
The test you propose ignores the friction on the sides of the stake, which may well dominate its load bearing capacity.
/ Finding soil bearing capacity? #7
The biggest reason foundation issues are so common in my part of the country, East Texas, is because so many builders failed to identify the type of soil they where building on and just went with the same slab foundation design everywhere they built. Knowing what type of soil you have is very important to knowing how the foundation must be designed. There are dozens of types of clay, and all sorts of mixtures of soils out there. Once you identify the soil, you can look up on a chart to see what it's rated for. You can also buy the tool that measures the soil and test it at every corner and along the lines of the footings. If it's poor soil, you usually just go deeper and wider. Sometimes you have to add additional load bearing beams into the ground to tie it all together and help support the weight of the house. An average house weighs something like 300,000 pounds.
Eddie
I got a call back from NRCS who said they referred the question to their soils engineer who can presumably give me a better answer. I will say this though-the subdivision I live in is built on a former 300 acre farm. According to the soil survey, the loam is more than 10' deep. My basement is maybe 8' deep. There are also homes and other outbuildings on slabs and plenty of driveways all in fine shape. I get that it's not bedrock, but it would surprise me to learn that its that poor?
I think you're thinking of pilings? Everything I've read about pouring piers refers to footprint as it relates to the bearing capacity of the soil-bigger footprint (area) means more bearing capacity. Pilings are driven (usually until refusal) and are often tapered, which creates friction against the ground. Piers are just concrete columns that are cast and then backfilled. Even if the backfill is well tamped I can't see it creating as near as much friction as a post hammered into the ground.
I know what type of soil I have, I just haven't been able to find any type of rating. The NRCS report does describe it as "suitable for building," but that's it. I will wait to hear from the soils engineer.
/ Finding soil bearing capacity? #9
You don’t say where you are, is it somewhere that doesn’t have standard building codes to use as guidelines? Also check to see what spec’s other foundations near you have been built to. One place to not skimp on are foundations, is darn hard and expensive to come in later and beef up. Pay close attention to if your soil is prone to shifting ( not related to frost line) , sections of Texas for example, which require unique foundations. Bigfoot /bell footings work very well over plain straight poles/ cassions as long as their base ground remains stable throughout the building life. You do figure in sidewall friction on deeper cassions but it really doesn’t factor in on shallow footings, so you may need to go deeper to find better load bearing soil, larger bell footings or more footings.
I'm in NJ-I don't think we have anything too exotic here in terms of soil. I've heard lots of horror stories about expansive clay soils in the Midwest/West, but I don't think that's case here. Homes are either slab on grade or plain old foundation walls and footings. I've gotten my zoning permit and am in the process of preparing drawings for the local inspector so he'll of course chime in, but the other purpose of preparing the drawings is to also put together a material take off sheet so that I can shop it around at the local lumberyards. The difference in the number/size of piers will affect my bottom line in terms of how much concrete, how many tubes/footing forms, and how much digging I have to do.
/ Finding soil bearing capacity? #11
Dave,
That is all Civil Engineer territory. Foundations, soils, and Structures are all classes that I have taken. Architects design for pretty and mechanical engineers design for movement, neither of which will make a building stand. :thumbsup:
To the OP, A soil proctor test and a shear test is the only thing thats going to get you what you need. It must be done in the field as well due to the large effect that moisture has on the strength of soils. Or it can be calculatd based on an assumed moisture content. Water does some very interesting things to soils when its under pressure. A soil will also gain some strength when the water is pressed out of it. (Compacted or consolidated) The cheapest option would be to play it conservative. I would be asking around to the local builders and see what they have been using. I would also be looking for some neighbors with older buildings to figure out how they were put in. You might be able to go to the local college and the grad students might run the test free of charge.
why are you so concerned about the pile weight capacites? You should never build with a factor of safety of 1:1.
For all I know I need not be concerned. I just figured I'd draw on the knowledge base here. I'm sure there are plenty of buildings around where some poles were thrown in the ground, backfilled, and stuff was built on top of them after someone said "Yep...looks good." That's just not my style.
/ Finding soil bearing capacity? #13
Nor should it be. I appreciate the forethought your putting into this. My question was more related to the weight of the building. I.E. What type of weights or structure are we dealing with in particular? A broad load is much easier to deal with than a point loading is. Not so much as to why in the world are you considering designing this. I'm all for making sure something is built the right way. My bad.
Basically I'm building somewhat of a "hybrid" pole building. My original intent was to build a fairly simple polebarn with 6 x 6 x 16' uprights on 48" deep, 18" diameter x 12" thick footings. However, the water table (especially right now) at my building site is very high. Based on that, I came to the conclusion that putting posts in the ground, treated or not, was a bad idea. What I decided was to put in piers and then bolt a 6 x 6 grade beam/sill to them. Inside the perimeter of the sill I'll be backfilling with clean fill, compacting, and then topping it with stone screenings. After that, I'll stick frame the walls and build a pretty conventional 16 x 24 barn. The piers will be carrying the weight of the walls, roof, and two 8 x 16 lofts at either end of the building. The lofts will be used for storage of out of season stuff like clothes, Christmas decorations, etc... Heavy stuff will be on the floor and therefore not imparting any load on the piers.
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Unused 2025 HD Trailer Solutions EQ17.5 20ft. 8 Ton T/A Equipment Trailer (A59230)
Unused 2025 HD...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
