Finding small air leak in front tire
   / Finding small air leak in front tire #1
310-510
Golden Valley, AZ
Kioti CK3510SE HC, Kubota BX24
One of the front tires on my BX24 was losing about 3 psi in a 24 hour period. I tried the soap and water and did not have any luck locating the culprit. By using the loader bucket to lift the tires, I was able to slide a tub under the tire, fill it with water, and wait!! and wait!!
Finally, after about 15 minutes of searching, I found it. One small bubble every 15 seconds.
Total time 30 minutes. 10 minutes to locate the tub, 15 minutes to locate the leak, 5 minutes to plug and put in the air.
It sure was nice not having to spend the 15.00 to have the tire fixed. (and there was no real manual labor)
   / Finding small air leak in front tire #2
Put a can of "fix-a-flat" in it and your problems will be solved forever..
Make sure you DO read the directions real good and follow them to a T
works for me :D
Jim
   / Finding small air leak in front tire #3
Now I have seen it all. A Kubota soaking it tire after a hard days labor. Next thing the hour meter will cause the engine to shut down after four hours of running time. There must be a union card in there someplace.
   / Finding small air leak in front tire #4
Plugs dont always work well in the side wall, I agree some slime or even the dreaded fixaflat might have done you better. Good luck.
   / Finding small air leak in front tire #5
First (and only so far) flat on my 4010 front tire, I didn't bother finding the leak. Just filled with air, slimed it, moved to other side and slimed that one, too.
Ralph
I like that. Yup, after a hard day at the office, my Kubota needs a "foot" bath. Maybe even a "foot" massage! Oh, and no, the Kubota does not shut off after 4 hours of running time, I do. On second thought, I don't make it 4 hours, at least not without a nap. :rolleyes:
Alright, with all the experience everybody else has in the forum, I heeded the advice and purchased a jug of slime. Should be here next week.
Thanks for emphasizing what I read about in other topics about slime but was procrastinating purchasing. Guess I'll test the slime out against the cactus plants around here.
   / Finding small air leak in front tire #8
works for me :D
Jim
I've got a 2 wheel dolly here at work with the 8" tires. Small leak that won't go away. So far I'm up to 4 cans of Fix a flat and it still leaks. One day it will be filled with solid fix a flat and maybe it'll hold.
If I use green slime my tires will just bleed green....and keep leaking. Maybe it's the heat down here. I just keep an extra tube for the front and rear around the place. :D
   / Finding small air leak in front tire #9
If 'Fix a flat' is what you call the stuff in the spray can, I've found it to be pretty useless to be honest. Slime is much better. I had one front tyre puncture that was a half inch long. I tried plugs and slime but that still wouldnt stop it because the tyre flexes so much. So I took off the tyre, glued a 4inch square of heavy old curtain material over the hole (on the inside of course), coated it with more rubber adhesive, then finally slimed it. Fixed at last!
   / Finding small air leak in front tire #10
Actually, Slime's website says it won't fix sidewall leaks.
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
