Finding small air leak in front tire
   / Finding small air leak in front tire #1
310-510
Golden Valley, AZ
Kioti CK3510SE HC, Kubota BX24
One of the front tires on my BX24 was losing about 3 psi in a 24 hour period. I tried the soap and water and did not have any luck locating the culprit. By using the loader bucket to lift the tires, I was able to slide a tub under the tire, fill it with water, and wait!! and wait!!
Finally, after about 15 minutes of searching, I found it. One small bubble every 15 seconds.
Total time 30 minutes. 10 minutes to locate the tub, 15 minutes to locate the leak, 5 minutes to plug and put in the air.
It sure was nice not having to spend the 15.00 to have the tire fixed. (and there was no real manual labor)
   / Finding small air leak in front tire #2
Put a can of "fix-a-flat" in it and your problems will be solved forever..
Make sure you DO read the directions real good and follow them to a T
works for me :D
Jim
   / Finding small air leak in front tire #3
Now I have seen it all. A Kubota soaking it tire after a hard days labor. Next thing the hour meter will cause the engine to shut down after four hours of running time. There must be a union card in there someplace.
   / Finding small air leak in front tire #4
Plugs dont always work well in the side wall, I agree some slime or even the dreaded fixaflat might have done you better. Good luck.
   / Finding small air leak in front tire #5
First (and only so far) flat on my 4010 front tire, I didn't bother finding the leak. Just filled with air, slimed it, moved to other side and slimed that one, too.
Ralph
I like that. Yup, after a hard day at the office, my Kubota needs a "foot" bath. Maybe even a "foot" massage! Oh, and no, the Kubota does not shut off after 4 hours of running time, I do. On second thought, I don't make it 4 hours, at least not without a nap. :rolleyes:
Alright, with all the experience everybody else has in the forum, I heeded the advice and purchased a jug of slime. Should be here next week.
Thanks for emphasizing what I read about in other topics about slime but was procrastinating purchasing. Guess I'll test the slime out against the cactus plants around here.
   / Finding small air leak in front tire #8
works for me :D
Jim
I've got a 2 wheel dolly here at work with the 8" tires. Small leak that won't go away. So far I'm up to 4 cans of Fix a flat and it still leaks. One day it will be filled with solid fix a flat and maybe it'll hold.
If I use green slime my tires will just bleed green....and keep leaking. Maybe it's the heat down here. I just keep an extra tube for the front and rear around the place. :D
   / Finding small air leak in front tire #9
If 'Fix a flat' is what you call the stuff in the spray can, I've found it to be pretty useless to be honest. Slime is much better. I had one front tyre puncture that was a half inch long. I tried plugs and slime but that still wouldnt stop it because the tyre flexes so much. So I took off the tyre, glued a 4inch square of heavy old curtain material over the hole (on the inside of course), coated it with more rubber adhesive, then finally slimed it. Fixed at last!
   / Finding small air leak in front tire #10
Actually, Slime's website says it won't fix sidewall leaks.
2012 FORD 4 DOOR TAURUS SEDAN (A52576)
2012 FORD 4 DOOR...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
