Finding a buried plastic pipe
/ Finding a buried plastic pipe #1
Travelover
Elite Member
Washington
B7100
My house is built half way down a hill and in recent storms I've started getting a little water in the basement. The grade near the house is OK and I have downspout extensions, clean gutters, etc.
It occurred to me that the 4" corrugated plastic pipe that drains the foundation used to stick up out of the ground near the creek that flows through my property. Over the years, the end of the pipe has disappeared as the creek has deposited silt in the area. Also small brush has grown up in this area.
I tried running a string across where I was sure it must cross and probing along the string as deep as I could (about 18") with a 3/8" steel rod, but there are a lot of roots etc in the area and I was unsuccessful in finding it. The area is swampy enough that I can't get my tractor in there to, for instance, pull a subsoiler bar through the earth.
The top end of the pipe is buried 4 feet in the ground at the foundation footer, so I can't easily insert something like a steel cable or sound source from that end. I know some will suggest water witching, but I've never gotten it to work for me and I'm especially skeptical for plastic pipe.
Any additional suggestions?
/ Finding a buried plastic pipe #2
Dig a trench perpendicular across where the pipe is likely to be located. Then you will intersect it and can get something in it to clean it out.
I had to do this to find a buried septic tank lid, when it was -15 deg F and I had no idea where it was located. Finally found it about 5 1/2 below the surface. All I had was a pick and a shovel to dig with.
/ Finding a buried plastic pipe #3
This spring I had the same situation, well except that it wasn't a stream that made the deposits covering the footing drain. It was me. We leveled a fairly large area of sloped ground covering the pipe completely. (We just moved in to the house and didn't know there was a footing drain pipe there).
Anyway This spring with all the rain the basement flooded :(
Having no idea where the pipe was I decided to dig a trench perpendicular to how I thought the pipe traveled. I was about 60' away from the house and about 25' away from where the pipe use to exit (reach the surface).
There was still frost in the ground, I had to dig a trench about 20' long 2' wide 3 - 4' deep before I finally hit the pipe. I knew it immediately because the trench filled with water.
I then turned the machine and started digging in the direction of where the pipe would exit the bank. now about 50'. and let the water drain for a day.
The water kept flowing and flowing....
Because we had a muddy floor on the bottom of the trench and I knew if I put the pipe in it would either be broken of not follow correct flow... We got 5 yds of 3/4" gravel. Once the bottom of the trench was close to the correct grade (I did 1.25" per 10'). we put gravel on the bottom of the trench filling the mud until it was solid and then laid the pipe on the gravel and then carefully back filled around the pipe with more gravel (basically the sides and barely covering the top of the pipe). This held the pipe firmly in place and then we carefully back filled with the dirt we removed (Making sure that any large rocks were not in contact with the pipe).
Amazing how much water flows out of the pipe! It is no wonder that our basement flooded.
I agree that a trench would do it. Problem is that it is so wet that even a tracked trencher might get stuck and I'm too lazy to dig that much trench by hand :D.
It may dry up enough by this late summer that I could get my tractor in there or a trencher, but I was hopin' for an alternative solution.
/ Finding a buried plastic pipe #5
Try some die if you can.........just put it in one end if possible and eventually it will come out the other.:thumbsup:
/ Finding a buried plastic pipe #6
Is it wet the full length of the buried pipe? I was thinking it wasn't and you could transect across the pipe some ways above the wet area.
The pipe starts out 4 feet underground midway up the hill, then descends to the creek level were it used to be visible. I'm not sure how deep it is buried between the start and end, but I suspect it is a lot deeper in the hillside than it is once it hits the flood plain. Also, the hillside is wooded now, so any trenching would be most practical between the base of the hill and the creek.
The dye idea is interesting. How could I best get it down to the pipe inlet? Maybe dig a hole next to the foundation, pour in some dye and a bunch of water?
/ Finding a buried plastic pipe #8
Do you have any cellar floor drains ? They usually tie into the footer drain.
/ Finding a buried plastic pipe #9
I would suggest a small hole near the foundation and pour the dye in.....eventually it should find its way into the pipe. Good luck !!
/ Finding a buried plastic pipe #10
ask a plumber with a locator to send in a snake and track it....might cost a few bucks but won't dig up the lawn or field which is wet anyway.
/ Finding a buried plastic pipe #11
Sure sounds like tree roots and sediment. What kinds of trees? I understand cottonwoods are real good at clogging septic systems.
I'd start with the dye. If it works, it is a lot easier and less messy than trenching.
For dye, you might try Mrs. Stewart's Bluing. When I was a teen, my parents had a pool. If we had failed to keep up with the chlorine and the water was a little green, we'd pour in some bluing and have blue water when guests came over. You get a lot of blue out of a little bottle.
Let us know how things work out and what actually works for you.
/ Finding a buried plastic pipe #12
In my neck of the woods, I can hire day laborers for $12.50 per hour. They have never gotten stuck in the mud and a pair can dig a prodigous amount of trench in a day.
I believe that the floor drain in the basement goes to the septic tank, but I could be wrong. Wouldn't that have been code in the mid 1960's?
Where would the plumber enter the system from? There are no clean outs on the footing drainage pipe, as far as I know.
No cottonwood trees and it is so wet here, there is no reason for them to go after the drain pipe. I'll post when I have a solution.
In my neck of the woods, I can hire day laborers for $12.50 per hour. They have never gotten stuck in the mud and a pair can dig a prodigious amount of trench in a day.
Interesting idea. I have not heard of anyone hiring day labor around here (SE Michigan), but maybe there is an underground labor market that I'm unaware of.
My next step is to buy some dye and dig a hole next to the foundation.
/ Finding a buried plastic pipe #14
"Interesting idea. I have not heard of anyone hiring day labor around here (SE Michigan), but maybe there is an underground labor market that I'm unaware of. "
During the week, drive a white truck into any parking lot at a Home Depot, Lowes or other big box store, you will get the day laborers.
/ Finding a buried plastic pipe #15
I have a sure fire way of locating buried pipes and cables. Have my wife come over and tell you EXACTLY where she wants the new roses planted. Start digging in that location. 100% Guaranteed to find pipes, coax, or phone line. Don't ask me how I know this. I just do. ;)
This is my emergency backup plan. Works for gas lines and buried electricial lines, too. :laughing:
/ Finding a buried plastic pipe #17
Around here any color truck works. If you drive up close to the store and park they stay away, if you drive to an empty part of the lot and park, they come running.
/ Finding a buried plastic pipe #18
Cellar floor drains going into the septic ? I would hope not. That would make one nice mess if the tank backed up.
The drain for the washer might go into the septic
So............what method did you settle on and with what results please ?
Still no joy. I dug a hole next to the footing 4 feet deep and emptied a gallon of water mixed with two packages of orange Rit clothing dye. Then I filled the hole with water a couple of times before filling it in. I still can't see any orange dye in the area where I suspect it exits. We have had very little rain since I dumped the dye.
I also cleared all the shrubs from an area about 6 feet wide and 75 feet long where I am almost sure the pipe passes. I dragged a subsoiler back and forth at a depth of about 12 to 14 inches, without success.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2014 GMC Savana 3500 Cargo Van (A59230)
2014 GMC Savana...
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
