Snow finaly blown snow
/ finaly blown snow #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Well here in Saskatchewan we got some snow, my CK20 was stored over winter last year waiting for our new house to be built and alas its not built yet, we had 4 to 6 inches of snow on the ground, drifts way more, I used the old faithfull Case 444 at the house and it blows prety good but, on the acreage I played with the CK20, not to mention the Schulte blower is heavier than the complete Case with all of its attachments combined it is awsome, got over the rear blowing fast, our drive is 1500 meteres and once you get going its pretty straight, I even stopped the blower, using the loader piled snow and tried it in deep packed snow, this tractor is awsome but too bad its back in the trailer, I played (slaved) for 3 hours and enjited every second, last month I backfilled the basement, leveled the yard, dug pond and my new project will be a tree planter, this spring planted small trees, 500 of them, the ground was hard so we rototilled some 5 acres to soften the soil.
/ finaly blown snow #2
Yup, these little machines are incredibly stout. My finance laughs at me because I go up to the highway where the plow trucks pile all the snow at the end of our road and snowblow the piles back into the woods, just because I can. :D
I can't wait for more snow:
/ finaly blown snow #3
lucky... I have to resize my pto to use min :( we just got 8+ " today had to use me fel to clear it... heh had fun scalping the lawn some more
:D
/ finaly blown snow #4
Dmace-
How far does your 3-point throw the white stuff on your CK20?
/ finaly blown snow #5
It all depends on the type of snow. This last storm was 9-1/2 inches of light fluffy dry snow and at 2800rpms (540 pto rpms), the snow goes about 30 feet out at a max height of about 8-10ft. As I go through real packed heavy stuff like the snowbanks, it only goes about 10-15ft out and about 6-8ft high.
Here is a short video of my snowblower in action. It doesn't show how far the stuff goes though, I need to make a new one.
Snowblowing
/ finaly blown snow #6
It looks like it throws pretty good - so thanks, you answered my question.
I like the video but you need an assistant to shoot the footage!
/ finaly blown snow
Hi BX24, here in central canada the snow is not wet, at -30deg C it is too cold, with a foot or more drift the CK20 will throw 24 to 30 feet, warmer temperatures the snow is wet and will only make 15 feet, if I slow the speed of the tractor it will throw further but 15 feet is lots.
/ finaly blown snow #8
I was getting rid of 12-15 inches of drifted snow yesterday and my 5' Meteor was throwing it about 25 feet. Snow was dry. I had to go failrly slowly, but it was moving it quite well.
/ finaly blown snow #9
12-08-07 cabin snow 006.JPEJust a little snow in northern Michigan,,,,the DK45SE works nice
/ finaly blown snow #10
Just a bit in Catt County.
/ finaly blown snow #11
TH, Do you use that rear blade for snow removal? If so.. how well does it work? Are there things you can do with the rear that you can't with the front? I am still deciding on FEL only, front blade, rear blade or blower for snow removal. I have 2 gravel/grass driveways totalling 225ft, and a 1/3 mile long gravel road I might help keep clear.
/ finaly blown snow #12
If you use a rear blade get a tall one. Landpride makes several heights ie rb2572 which translates into 25" inchches tall, 6ft wide. I have used rear blades on both previous tractors and with wet snow in particular when moving forward the snow will get caught on the central support member. Also, you are limited on how much snow you can drive through before you lose traction. I maintain 1100 feet of gravel driveway. 500 feet is level and 600 feet is a steep climb. 200 feet of that steep climb is at a 20 degree slope. I really liked the rearblade. When the gravel wasn't frozen it would not dig in like the fisher plow on my plow truck. Having the front loader free came in handy but like everything there are trade offs.
Why have both?? Through the years the plow truck has proven to be really brittle. It must have been a "monday" truck.
Jim
/ finaly blown snow #13
Snowblowing
So how cold it when it snowed? I was a little afraid that you were going to snowblow your camera. :D
/ finaly blown snow #14
Ha! Ha! Don't worry, I had the camera zoomed in a little so it would get a close shot and not be in harm's way. I don't remember how cold it was outside, but inside the cab it was about 70-80 degrees F. :D
/ finaly blown snow #15
When the snow got deep, I raised the front blade about 6" off the ground and dropped the rear all the way down. It worked "ok" but the snow would still tend to build up and want to lift the rear tires.
/ finaly blown snow #16
ToadHill I notice you have your rearblade tilted forward considerably. Is that so it does dig in as much? Also, how do you like that plow mounted out front? Been thinking about modifying one like that myself. I see plenty of old Fishers by the roadside for cheap. I currently use my FEL and a rear blade for the white stuff.
/ finaly blown snow #17
Willie: The rear blade normally sits level, it's just that way in the picture because I hadn't adjusted the toplink yet. The glade in front of the bucket works well I burned 2 holes in the bucket to slide the horns of the plow thru and then pin them. The blade is then hooked to the bucket hook with a chain.
With that setup, you can raise the bucket and plow as you get to the bank and pile the snow up to about 7 ft high without having to dump it out of the bucket.
/ finaly blown snow #19
Thanks for the info, I too would like to see some close ups of that plow setup.............. looking to steal(borrow) some ideas.
/ finaly blown snow #20
I have a personal use plow(SnowBear) off my GMC Yukon I kept when I traded. I drilled two 3/4'' holes in my cutting edge to bolt the mount in,took the winch that SnowBear used to elevate the plow, off the push arms and used a ratcheting chain binder to secure the lift arm to the center bucket hook.Works really well unless the snow is heavy,wet stuff.The blade doesn't have enough weight to keep it planted on the asphalt.I'm still cogitating a snow blower but am having trouble getting past the price:eek:
