FINALLY!
/ FINALLY! #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
Got my new trailer. 20+2', 6k dexter axles, led's, winch mount, spring assist ramps, 10k jack. I should be able to haul my junk all around the place now!
One problem, where should I put the tags?
/ FINALLY!
6k, 9300 lb capacity.
/ FINALLY! #5
hr,
Nice trailer.
I put my license plate vertically on the back of the fender. It might not be totally correct but I've never had a problem. I see a lot of them that way and it gets it out of harms way. If you added a license plate light in that location you'd never have a problem.
/ FINALLY! #7
By law, at least here in Indiana, they must be under the left tail light with it illuminated at night. If you look under your light there is probably a clear lens to let some of the running light illuminate it. You can get a rubber mount at any TSC or auto parts store that allows the plate swing out of the way if you bottom out.
Chris
/ FINALLY! #9
What brand is it? Are those tor-flex axles?
/ FINALLY!
/ FINALLY! #11
It might not be perfectly legal, but Dad and I both bolt our tags to the back side of the left-hand ramp. It's up out of the way there and well protected from damage. It's high enough to be at eye level at night, and car headlights illuminate it well. We've never had a problem...
/ FINALLY!
Solved that too. Got a $2 bracket from agrisupply that bolts to the light and flexes if it drags or hits something. Works perfectly.
2002 Pace American of Texas T/A 26FT Enclosed Trailer (A61573)
2002 Pace American...
MASSEY FERGUSON 4 BOTTOM PLOW (A63291)
MASSEY FERGUSON 4...
17109SFL (A61569)
17109SFL (A61569)
2349 (A64281)
2349 (A64281)
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
