Finally the slush pusher took its maiden voyage
   / Finally the slush pusher took its maiden voyage #1
c-and-a
Massachusetts
BX2350
We had our first snow/sleet/rain storm that left enough slush to give it a try...and it worked as expected - it's one mighty squeegee...
No issue back-dragging and no issue dumping the FEL - very limited wear on the rubber. So I am very pleased with the outcome.
I realize I do not have a massive driveway like some, but I basically "plowed" with this setup as opposed to scoop and dump which was extremely fast and painless.
   / Finally the slush pusher took its maiden voyage #2
No action shots???
ron
   / Finally the slush pusher took its maiden voyage #3
That would not have worked here with this storm. I used the bucket to break through and scrape up 1"+ of ice.
   / Finally the slush pusher took its maiden voyage #4
Just curious, would it clean as good if someone would have driven over the wet snow and slush and made tire tracks??? By the way, you may want to patent the idea, it looks like it could catch on :D . Good fabrication :) .
Bill
   / Finally the slush pusher took its maiden voyage #5
yea I was out there today too, I was going to use the snowblower on the little tractor but said screw it and took the tooth bar of the big one and went at it, I do love that idea. I think I would need one taller and on am angle
   / Finally the slush pusher took its maiden voyage #6
Hey Curt, that seems to work great for your situation! Not sure I could use something like that with my 1000 feet of dirt drive (mud drive these days). Nice finished project and I am sure it will work for you for many years.
By the way, you have to get that bucket a bit dirty and scratched up!
Wayne
   / Finally the slush pusher took its maiden voyage #7
Just an FYI, you should probably take a bit of care posting photos with your license plate and mailbox showing your address.
Couple of responses:
My wife made several passes over the driveway with her full size SUV, it was not completely frozen, but iced-up - no issue scrapping it up...
It would be nice to have an angle on it or angled wings (rev 2)
Easy on, easy off with the clamps - allows for bucket scrapping when necessary...
   / Finally the slush pusher took its maiden voyage #9
c-and-a, congratulations for a beautiful piece of engineering.
It's well thought out, very clean assembly, with an ingenious "easy on - easy off" design.
Were did you find the rubber?
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
