Snow Finally, some snow!
/ Finally, some snow! #21
Hi all:
Yes I have the standard woods blade feel like about 300#hand swinging it. Think the concrete is the answer why I don't have a ridge maybe 1 side of blade might be a little lighter but it can't dig into street/drive. In air and angled 1 side is higher. Think as suggested will keep doing what I'm doing or maybe even throw some weights over top of blade and see how goes can't hurt as trial.
Thanx Pat R
Stargazer said:
Hi all:
Thanx Pat R
300 lbs. sounds about right, given the heavy-duty quality of Woods stuff. My blade is an el-cheapo KK standard blade, and it weighs a hefty 250 lbs. With 300 lbs. I can't see the need for weights in order to push snow around. Without weights on my blade, I re-graded the gravel driveway twice last year.
/ Finally, some snow! #23
Pmonkey,
This is what I was talking about.
ron
/ Finally, some snow! #24
Could it be, is that white stuff falling from the sky, my God, it is, IT'S SNOWING!!!
/ Finally, some snow! #25
Plowed five driveways in my neighbor hood before noon today. Never hurts to be neighborly. Went to three of my favorite neighbors' houses and, on the way back, saw a new neighbor (age 80) struggling with a shovel. Needless to say, I have a new friend. Not enough "being neighborly" in the world today in my opinion.
/ Finally, some snow! #26
I've got an older 6' blade. Not sure who made it. You should be able to see the round wheel on the blade. The blade tilt can be adjusted so it sits flat as needed when angled or straight.
638 said:
Pmonkey,
ron
Okay, thanks for the photo. That helps alot. Do you find the solution stable? It looks to me like the chain could come undone at the hook end with all the shaking around my blade does?
/ Finally, some snow! #28
now I see the benefit of the tilt feature even for just removing snow. After reading the posts in this thread I experimented with the top link on my B7800 and now have it longer as it keeps my 6 foot KK rear blade more level.
/ Finally, some snow! #30
Pmonkey,
No problem yet, as we have had no snow in sunny southern Indiana this year. I left the chains a little long, and think the weight will help hold them in place. If not a little tape should do the trick.
ron
/ Finally, some snow! #31
Don't feel bad, Ron. Here in NW Ohio, we had exactly 1" for our one and only snowfall this year. Getting mighty depressing. On the slightly funny note, there I was, plowing that 1" of snow. What makes it worse is I actually sat there when I was done, thinking about getting all my neighbors drives as well. Didn't think I could handle all the laughing and pointing though... *sigh*
/ Finally, some snow! #32
How about 10" ..
Basically took our city to a stand still
3" of ice under this..
Big Circle Drive up a 200' Hill... Thank God for my FEL.. Notice the pile at the end of the drive... That's my neighbor with his plow at the bottom....
Together we made a great team, but it still took us nearly 4 hrs to get it done.. Of course, we were doing it while it was still snowing an inch / hour.
This isn't one I'd want to do with an FEL all the time...
/ Finally, some snow! #33
Well snow is SE Michigan is not cooperating with the need for seat time. But it is getting there. 1/2" to 1" at a time. With the temperature staying below freezing. We will over 12" on the ground by February 1st. :)
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
