Finally put together a this to check pressures
   / Finally put together a this to check pressures #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I used a Tee between two quick couplers. I can either just connect to a remote, or "tee" into something.
The only reason for the 90 bend in the hose at the tee is Surplus Center had this hose for 1/3 the price of a std hose the same length. It took one more adapter to make it work.
I just can not use it on my loader because I swapped the quick couplers (six) for a Multi-Coupler.
   / Finally put together a this to check pressures #2
How much to put that together?
NO idea :confused3: I had the quick couplers from when I swapped to the Multi-Coupler on my loader. Was given the gauge. I had some of the fittings and bought a few. The hose was $4.99. bet I spent $15 - $20 tops.
If I had to buy everything new, it never would have been built.
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2022 Continental 16' Enclosed Trailer with ramps (A49461)
2022 Continental...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
1268 (A50490)
1268 (A50490)
