Finally put together a this to check pressures
   / Finally put together a this to check pressures #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I used a Tee between two quick couplers. I can either just connect to a remote, or "tee" into something.
The only reason for the 90 bend in the hose at the tee is Surplus Center had this hose for 1/3 the price of a std hose the same length. It took one more adapter to make it work.
I just can not use it on my loader because I swapped the quick couplers (six) for a Multi-Coupler.
   / Finally put together a this to check pressures #2
How much to put that together?
NO idea :confused3: I had the quick couplers from when I swapped to the Multi-Coupler on my loader. Was given the gauge. I had some of the fittings and bought a few. The hose was $4.99. bet I spent $15 - $20 tops.
If I had to buy everything new, it never would have been built.
Rhino 116 Flex Wing Offset Disc Harrow - Heavy-Duty Tillage Tool - Selling Absolute, No Reserve (A51039)
Rhino 116 Flex...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
