Snow Finally got to blow some snow
   / Finally got to blow some snow #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
I finally got some snow a couple days ago and got to have my first serious snow blowing session, here is a few pics of my play time.
   / Finally got to blow some snow #2
Looks like fun.I like the dual rears.:thumbsup:
It was a blast and the dual rears helped with the traction and stability a lot.
It was fun and the duals helped with traction and stability a lot
(sorry for the double post the app said the first reply didn't go through)
   / Finally got to blow some snow #5
Any close up pics of your blower wings?
Also how much wider does it make the blower
The blower is 50" wide and the wings make it 80" wide so it is 30" wider
   / Finally got to blow some snow #8
Interesting setup.
Dual tires are for only winter use?
   / Finally got to blow some snow #9
I also have this same set up; Kubota 2660 with a front snow blower (minus the wings of course) and I'm trading my unit for a couple of reasons.
- Blower unit can get bogged down in heavy wet snow, Unless your pushing cold light snow (where it does a great job) I'd would suspect that the wings might add to the capacity problem, at least where I live.
- The progress can be slow if there is a volume of snow. The machine has more than sufficient power but my blower unit can break shear bolts (on pavement) if you don't take your time.
- Changing shear bolts on the impeller shaft can be a frustrating experience in this sized blower unit, as you have very little room to work.
- The after market Curtis cab is very noisy. Have to wear ear protection at all times.
- Having said all that, I have never had a traction problem, with or without a ballast box....but the duelly wheels sure do look cool. You look like you could be on a ski resort!
I will miss my 2660, as we have worked through a bunch of wicked storms together. She was my first tractor. My new rig arrived at the dealer last week (picking her up tomorrow). I am trading the BX2660 on an L4240 with a factory cab. This time I've decided to add the blower on the back with a plow on the front. The aim is to plow, then blow it where I want it. This will allow me to use the tractor even if it's slushy. We all know blowers are not fans of slush.
Sadly, I will likely have to wait until next winter to try out my new L4240. I will post pics once she's delivered. pat
Carl Bert said:
What model tractor is that?
That's a BX2660 heavily modded. It has rear remotes, duals for the rear, the cab, it has a 7 round trailer hook up with a trailer brake controller, it's got pats quick hitch, hydraulic top link, electrical hook-up for things like sprayers, the hydraulic bypass is set up to 2000 PSI for a LOT more power (I want to go higher but I'm not sure how high I could go before it gets too much for the tractor.) The FEL stick is shortened considerably and has an electrical thumb activated switch. Right now I'm working on a way to pressurize the cab.
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
