Finally got the toolboxes mounted on the CK 27
   / Finally got the toolboxes mounted on the CK 27 #1
Mike Gibson
Dufur Oregon
Kioti CK 27
I finally got the tractor back from the kids and had a chance to install a toolbox for the lifting & pulling gear. The box sits on two 1/4" X 2" flat bar brackets bent to cradle the loader arm and support the toolbox. I used two 1/4" bolts to hold the brackets to the loader arm.
Right after I bought the tractor I installed a larger toolbox behind the seat. The plastic item that came stock was a joke.
I added the "Easy Rider" rifle rack for varmints that seem to appear when you have no gun with you. With the shovel I first tried sticking it in the hollow of the bucket pipe. I couldn't keep it from rattling something awful so I just bungee it to the pipe now.
The chain box. I put it on this side so I could see the right side of the bucket as you lose a bit of visibility with the box.
The rear box.
The rifle rack.
The shovel in place.
Side view.
   / Finally got the toolboxes mounted on the CK 27 #2
Looks handy. Thanks for posting.
   / Finally got the toolboxes mounted on the CK 27 #3
I've never seen a tool box on the loader arm....interesting.
   / Finally got the toolboxes mounted on the CK 27 #4
Very nice!
Do they quick detach somehow, or are they bolted on?
Tractor on
There are two 1/4" bolts that keep the brackets from coming off the arm. The one in back is bolted like the stock toolbox was. I put polyurethane foam in the bottom of the toolbox on the arm so things don't rattle around and get beatup.
2000 Ford F-450 Dump Truck, VIN # 1FDXW46F5YEB20130 (A57453)
2000 Ford F-450...
(INOP) YAMAHA GAS GOLF CART (A58374)
(INOP) YAMAHA GAS...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2000 HAULMARK K716BT-WT 7' X 16' CARGO TRAILER (A52708)
2000 HAULMARK...
2017 GRAND DESIGN RV MOMENTUM (A58214)
2017 GRAND DESIGN...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
