Tires Finally got my tires loaded
   / Finally got my tires loaded #11
coffeeman said:
I have a big brush hog for my tractor. I can pick it up ok. But, the fromt of tractor is a little light and sort of floats along. I usually keep hog down to make tractor stable. I was wondering if front wheel water would help that problem out. I thought I'd try it.
Coffeeman
If your front tires are fairly large it will help a lot. 3benefits: weight to keep the front planted, weight not supported by the axle/bearings, tires have a higher compression ratio so the unladen air pressure can be less - it actually seems to ride better due to this. Be more careful over very bumpy sections because you will have lost some 'spring'.
larry
   / Finally got my tires loaded #12
Savagepike said:
A word of caution... I've always been told to never fill the front tires. I'm not sure the technical reasoning behind this, but since it's been said so many times, it might be safer to follow the consensus.
I very well could be wrong, but I believe that there are a hand full of us that have all 4 tires filled. For me, the benefits of having the tires filled far outweigh :D any negatives. The only draw back that I can see would be if you had a smaller tractor and did a lot of finish lawn mowing.
   / Finally got my tires loaded #13
I've never really thought about this much so I looked in the manual and found this...
Fronts, only add metal weights, to bumper, max 220 pounds.
Rears - wheel weights or liquid.
wheel weights - 185# per side max
liquid - only 75% full, do not fill tires if tractor is a CAB model
----------------------9.5x24---------11.2x24
2# of cacl2 per gal-----165#-----------227#
3.5#-------------------178#-----------237#
5#---------------------187#-----------253#
I had these big fat turfs on there first, it dosn't list those but I bet they help more water.
weight is each tire and the more cacl2 means more freezing protection. Not to much worry about that in east Texas. I just ordered the tool form gemplers. I have the 11.2x24 and tubed tires. Now where can I get some Cacl2? :)
For the math wizzards, can I calculate in the info that I have that the tire holds 8.6666 gallons of water? May not be able to with the info given. The manual doesn't say how much.
   / Finally got my tires loaded #14
No, you need one more piece of info. I have done tests with CaCl added to distilled water. 5# added to a gallon makes a solution that weighs 10.6# per gallon. Dividing that into 187 gives somewhere around 18 G/tire.
BTW 6#/G yields an 11#/G solution
7#/G gives 11.4/G but some of the salt precipitates out at 0F. Bottom of tire will be a little slushy with salt until it warms back up.
larry
   / Finally got my tires loaded #15
That's probably close enough for a guess. 18 gallons per tire.
Interesting.
Thanks,
Rob
   / Finally got my tires loaded #16
I have all 4 tires foam filled on a light tractor. No problem on my lawn. I love the effects generally.
   / Finally got my tires loaded #17
I have heard that is heavy and makes for a rough ride. Maybe not a problem on a smaller tractor. I have a friend that foamed his ATV tires. His comments were...expensive, work fine, but killed the ATV ride. He did not recommend it for ATV's. I think for my smaller front tires it would be great.
   / Finally got my tires loaded #18
Just got my mahindra 3510 front tires filled with the polyurethane foam. I will hopefully put it to work next week. little expensive but cheaper then putting new tires on it all the time.
   / Finally got my tires loaded #19
How does this help with reducing tire replacement? Does the foam prevent flats, or does it help with wear as well?
For those using liquids, other than reducing the center of gravity and increasing overall weight, are there any other advantages? Isn't there a concern of rusting rims by having them constantly immersed in water? Any concern over the chemcal reaction between calcium chloride and aluminum or steel rims, if known?
Lastly how would one go about loading tires, and what would be the optimum tire filling stuff, foam, wahesr fluid, antifreeze/water mix, cal chlor?
Thanks
KC
   / Finally got my tires loaded #20
Thanks
KC
Wear..IMO would be the same as not filled. For some reason I think if anything...more wear if the tire can't flex as much.
Mine have tuges, no metal contact. Check my recent posts for filling with water as a DIY and using a $15 tool.
Rob
Swict 66" Bucket (A57149)
Swict 66" Bucket...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
Toro TRX-20 Walk Behind Trencher (A57453)
Toro TRX-20 Walk...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
202476 (A54757)
202476 (A54757)
2128 (A58376)
2128 (A58376)
