SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,520
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
If your front tires are fairly large it will help a lot. 3benefits: weight to keep the front planted, weight not supported by the axle/bearings, tires have a higher compression ratio so the unladen air pressure can be less - it actually seems to ride better due to this. Be more careful over very bumpy sections because you will have lost some 'spring'.coffeeman said:I have a big brush hog for my tractor. I can pick it up ok. But, the fromt of tractor is a little light and sort of floats along. I usually keep hog down to make tractor stable. I was wondering if front wheel water would help that problem out. I thought I'd try it.
Coffeeman
larry
