Finally finished Disk Harrow
/ Finally finished Disk Harrow #51
wushaw,
Nice job on the disk. I especially like the star on top. /forums/images/graemlins/grin.gif
/ Finally finished Disk Harrow #52
wushaw,
/ Finally finished Disk Harrow #53
I think the star should be white ......red? .....guess I'm old enough to remember the cold war....
/ Finally finished Disk Harrow #54
/ Finally finished Disk Harrow #55
VERY nice work! Mine is a fairly light one made of angle iron & only adjusts the cutting angle with bolts. Yours is much heavier & the easy angle adjustment is pretty slick.
/ Finally finished Disk Harrow #56
/ Finally finished Disk Harrow #57
wushaw,
Excellent project!
I recently replaced 1 axle, 5 cutters, and 5 or 6 spools, and it nearly cost me as much as I paid for the disk harrow brand new. Although your disk is way better than a comparable bought one, it must have cost quite a bit more, right? Yours looks to have bearings instead of the spools, right?
A few observations from someone that's had a lot of trouble with disk harrows:
Grease, grease, grease. (assuming spools)
Butt welds on lower arm brackets will eventually give way.
The big axle nuts will try their best to loosen and destroy your axles.
Flat plate steel brackets holding the axles will flex back and forth. Gussets could make them stiff and quiet them down.
A good dog is worth more than a good tractor.
/ Finally finished Disk Harrow #58
wushaw,
Excellent project!
/ Finally finished Disk Harrow #59
Outstanding job on the disc!!
Nice tractor, nice dog.
What I'm really envious about is your beer can cover !!!
Cheers!
/ Finally finished Disk Harrow #60
Cheers!
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
