Finally building the house
   / Finally building the house #31
Looks great. If I had to build again, I would definitely look at poured concrete or ISP.
I am curious to see the next steps
   / Finally building the house #32
KennyG, no it is not common to go all the way , most stop at the basement level. I just thought that it made sense to build something that will be here long after I'm gone.
Eddie, the first floor and basement are 900sqft each, and the loft area is 600sqft. Not to big, but enough to be comfortable. Hydronic heat on all floors, nat gas boiler and two nat gas fireplaces. Walls work out to R60, Attic is R56.
Two spare bdrms , mech rm, theatre area, 3/4 bath and craft rm in the basement, 10 X 12 cold room off mech rm, main floor is kitchen, dining, living rm, pantry and entry off kitchen, 1/2 bath. Loft area is master suite 16 X 20, walk in closet 6 X 16, 4 pc Bath is 6 X 20.
Great job docone. Really impressive. Just wondering why you choose 8" core ICF all the way up? Are you supplementing insulation for walls to get R60? If is just standard 2.5" foam and 8" concrete, the wall will have max R22-25. Also, did you have the pex pipes in the slab for basement or what is your plan? How you will do it for upper levels?
Thanks, As I understand it,ICF foam has an insulation value of R 7 per inch, which gives me R35 for 5 inches. The concrete value in this configuration should add R20 to the wall, and the stucco finish on the exterior will boost it a bit as well.
Yes, there is pex in the basement slab, and copper heat runs in each joist space on the upper levels, basically a 1500sqft radiator. The gas fireplaces will supply make up heat as required.
   / Finally building the house #34
That's awesome. I've never saw foam with that high R value.
   / Finally building the house #35
I think the ICF values are "equivalent R-Value", compared to conventional stud and blanket insulation. Because the forms have no discontinuities (studs) they have a higher equivalent value than the foam itself. The conventional 2x6 stud wall would perhaps have blanket insulation with R-19. However, the studs significantly reduce the insulation value. Foam with actual R per inch of 5 might only need 3 inches or less of foam to be equivalent to R-19. Since Polyiso is only about R-6 per inch, I would guess the ICF is a little less.
   / Finally building the house #36
Yeah, I thought of that later. I Googled it. After a lengthy read about the things you mentioned it stated a 9" wall with 5" ICF would have an R value of 20.
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
1989 International 1 Axle Dump Truck (RUNS)(TITLE) (A50775)
1989 International...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A55745)
2015 PCI MFG...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
Giyi 39" Mini 4-n-1 Bucket (A53316)
Giyi 39" Mini...
