Finally bought a cutter
   / Finally bought a cutter #11
Rotary cutters are great for scalping high dirt mounds as well.. in fact.. I'm becomming a professional at it!
Soundguy
   / Finally bought a cutter #12
I can scalp with the best of them!!! /forums/images/graemlins/cool.gif
   / Finally bought a cutter #13
You're supposed to use the box blade to level the yard, not the cutter!
   / Finally bought a cutter #14
I haven't had a chance to call them yet. How much did they cost ya if you don't mind me asking.
"I haven't had a chance to call them yet. How much did they cost ya if you don't mind me asking. "
Not sure of whose post you're asking about, but if it's about the cutter I bought...$1060.00 including tax. This was in south central PA.
If it's about the Quick Hitch..can't help you.
   / Finally bought a cutter #16
Roy,
I think he meant the price on the Easy Change System that GaryM bought.
Jerry
   / Finally bought a cutter #17
Hi,
Pat's easy change system is $180 + $15 shipping. Got the package to the St. Louis area in two days. I had intended to do the install last weekend, but it was raining and the tractor's outside. Maybe this weekend.
There was some discussions about sway and the fact that the hooks won't line up in the lower pins as well as the normal ball ends will. And this might be a consideration with a high power machine. But I have a JD 4100 and I'm sure I won't have any problems. I'm anxious to get them installed as I need to change from the cutter to the box blade. And I need to mount a borrowed PHD in a week or two.
   / Finally bought a cutter #18
You are correct Jerry, I was questioning about the easy change system. Guess I should have specified. /forums/images/graemlins/blush.gif
   / Finally bought a cutter #19
RoyJackson:
OK, this is a little off the subject well, no this is way freaking off the subject. Has anyone else noticed that Roy and Soundguy look like the same guy???? /forums/images/graemlins/cool.gif
I was reading throught this post and there it was...both pic's on the same page, I was scrolling back and forth looking at the pic's on page two and I'm tell you I think there long lost brothers, Is it only me or do you guy's see the same thing???? /forums/images/graemlins/grin.gif
Just having some fun guy's hope I didn't piss anyone off.
Whiskey
   / Finally bought a cutter #20
<font color="blue"> I was also kind of concerned about not having an over running clutch on my PTO. I've heard cutter blade inertia can drive the tractors. No problem...but I'll get that over running clutch very soon. </font>
I am up on the X70 series JD's like I should, but does your 670 have a live PTO or 2 Stage Clutch? If so then you do not need the over-running clutch. They are only needed on tractor without built in over run couplers or tractor that do not have live PTO or 2 stage clutches.
Horse Statue (A55853)
2011 Ford Escape XLT SUV (A55853)
2011 Ford Escape...
Honda EM3800SX Portable Gasoline Generator (A55851)
Honda EM3800SX...
Swict 72" Quick Attach Bucket (A56469)
Swict 72" Quick...
2017 Freightliner 114SD Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2017 Freightliner...
2011 KUBOTA SVL90-2 SKID STEER (A52707)
2011 KUBOTA...
